Hey up all you guys.
I've got a minor problem. The disk of my front wheel is somehow rubbing on the post mount lugs on the fork. I have no idea why this is happening, I really don't think the forks have twisted, but also have no idea how it has happened.
I took the hub apart to change the bearings so there may be a spacer in the wrong place or something. But I am absolutely stuck. Is there anyway the centerlock disk may be the wrong way round?
The hub is shimano xt
Disk is shimano centerlock
Forks are fox f100's.
Thanks alot for reading.
Josh
sounds like you missasembled the spacers and locknuts on the spindle
its hard to say with out a picture. i would take it to a bike shop.
I'm pretty sure I didn't, It goes cone, spacer, locknut doesn't it?
I would have done, but the head mech is gone from the lbs and the rest are absolutely useless...
If it was ok, you stripped the hub and now its not the obvious answer is its something you did. clearance is only a few mm anyway
Yeah. Thats what i'm guessing also.
It does go cone, spacer, locknut though, on the non disk side doesn't it though?
I don't know brownmix. years since I did a shimano hub
You will probably be able to find an exploded diagram on the nest somewghere -
Just a thought - did you reverse it so undo the non disc side, rebuild it but install the spindle from the other side?
Hmmmm, i may have.... I will try that.
Report back tomorrow!
Thanks
