Help with my truly ...
[Closed] Help with my truly awful pictures please.............
 FFJA
[#2510230]
Well..tried to take a few half decent shot swith my new camera,(Fuji S1730) and pretty much everything came out similar to this beauty... 🙁
I think i had it in the Sport mode to try to get focus on the rider. Can anyone tell me/help me with what im doing wrong? Help very much appreciated i'm all frustrated!
Posted : 26/02/2011 11:06 pm
A bigger pic might help, and do you need sport mode from that distance/with that level of mincing?
Not that I'll actually be able to help, as I know bugger all about photography
Posted : 26/02/2011 11:20 pm
I might be wrong but i had a simelar problem that turned out to be a slightly damaged sd card..
Posted : 26/02/2011 11:45 pm
 FFJA
Hmm i suspect it isn't the sd card as indoor ones, odd one or two outside seem fine, im just unsure why its been over exposing the majority if stuff, almost to the point where some look like film negatives almost...
Posted : 27/02/2011 12:04 am
Try it in a 'normal' mode
What is the dial on the top pointing to? is it pointing to an icon of a green camera or A, M or something?
Posted : 27/02/2011 12:10 am
 Keva
is that the negative, of a night shot ?
i really dunno, just guessing...
Kev
Posted : 27/02/2011 12:14 am
 FFJA
I had it in SP mode on the little dial... More time playing needed i guess ...
Posted : 27/02/2011 12:34 am
SP mode is Scene Position mode - you've probably just selected some odd faux filter mode within that setting...
Within the Scene Position mode (SP) you can access 15 pre-programmed scene modes which allow you to really get creative with your photography!
[url= https://secure.fujifilm.co.uk/shop/consumer/digital/digital-cameras/d-slr-long-zoom/finepix-s1730/Features ]Looky here[/url]
Posted : 27/02/2011 12:53 am
Very hard to tell with such a small picture but it looks terribly over exposed to me. You're way too far away from the subject for a start and 50% of the picture is sky, not always a bad thing but in this case I'd say it is. Get a lot closer, pre-focus before the shot but half pressing while pointing at the subject view, make sure there's not a load of bright sky that you're not interested in, in the shot.
Posted : 27/02/2011 1:00 am
with respect, a damaged card would either work or not work, not affect the quality of the shots! But at that size it's impossible to see what's wrong, other than it looks overexposed...
Posted : 27/02/2011 1:28 am
Did you focus on the shadow under the tree and then press the button when the rider came past?
It looks like perhaps the shadow is exposed alright but because that should be a darker than average part of the picture the rest is too light; overexposed.
Might also be settings where somehow you've got the shutter speed set so slowly that its letting too much light in.
If you've got the ISO set too high then it might not help either, especially if the shutter speed cant go fast enough to compensate.
Does your camera give a readout out of settings? ISO, Shutter Speed and F number would all be interesting to see.
Posted : 27/02/2011 10:53 am
That's some in-camera setting doing that. Either some daft "get creative" filter mode or you've massively screwed up ISO, exposure and white balance all in one fell swoop!
Sit down with the instruction manual when you've got a bit of time, go through the camera settings and try it out, each time looking at the results on the screen or downloading them to the computer.
My settings tend to stay within a certain range - ISO is usually about 200-640, I tend to set my White Balance to cloudy and just leave it there - shooting RAW means I can change it afterwards anyway. A lot of the time I'll let the camera do the thinking, especially shooting pics while out riding. Only if I've got time to set up a shot will I start playing with Aperture Priority.
Posted : 27/02/2011 11:10 am
I've never noticed this - digital cameras can usually get sub millisecond shutter speeds
don't say that James or you'll be labelled clueless (like me)!
Posted : 27/02/2011 12:33 pm
 toab
I had a camera that turned any real sunlight into pink grainy streaks. Eventually turned out to a fault with the sensor and the shop replaced it on the warranty
Posted : 27/02/2011 12:39 pm
 FFJA
Thanks for the suggestions folks. From looking throught the manual and talking to someone with the same camera, it seems like its because i was using the setting where it will take frames all the time the button is depressed. The setting to just take 3 frames is the way forward aparently....
How should i have uploaded that as a full size from Flickr by the way?? 😳
Thanks
James
Posted : 27/02/2011 12:56 pm
 FFJA
The data for it btw was 1/160s f/4.2 ISO:64
Posted : 27/02/2011 1:02 pm
ISO 64 ????
Posted : 27/02/2011 1:30 pm
 FFJA
Erm yesss...I'm guessing thats not a good thing 😳
Posted : 27/02/2011 2:01 pm
well, the lower the ISO the better the quality till you reach the base sensitivity of the sensor - though it may be hard to see much difference - I shot everything at ISO 400 for 5 years before I noticed blue skies seem to render better at lower settings, but the higher the setting, the faster the shutter speed, which is better for capturing action and avoiding camera shake, until you run into the reducing quality of the recorded image.
Posted : 27/02/2011 2:10 pm
 FFJA
Thanks Simon, the light is almost exactly the same today so i'm going to go and retake the same shots a few times and see how i get on..
Posted : 27/02/2011 2:12 pm
On the photo page go to "Share this > Grab the HTML/BBCode", click the BBCode button, copy the text in the box and paste it here. You can choose the size as well.
Testing to see if I'm talking rubbish:
[url= http://farm5.static.flickr.com/4007/5129276093_a58cdd0234_m.jp g" target="_blank">http://farm5.static.flickr.com/4007/5129276093_a58cdd0234_m.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/cbhaf/5129276093/ ]Superstar[/url] by [url= http://www.flickr.com/people/cbhaf/ ]Michael (ffcnimmo)[/url], on Flickr
Posted : 27/02/2011 3:10 pm
