help a noob? - low ...
[Closed] help a noob? - low stack headset woes with mmmbop
[#1934729]
Bought an mmmbop frame and am attempting my very first build as and when paydays allow. However, low stack height = fail.
Any suggestions much appreciated! I really cant afford another headset at the mo. I reckon I need 3mm - cut a spacer and bash it on?! Buy a cheapo FSA fat pig (CRC £32) despite it's sh1tness?!
[IMG] http://www.darksnow.co.uk/g2/main.php?g2_view=core.DownloadItem&g2_itemId=3609&g2_serialNumber=1 [/IMG]
Posted : 26/08/2010 5:56 pm
What headset is it you've got there?
Posted : 26/08/2010 6:00 pm
Superstar Components Grande Bambino reducer
Posted : 26/08/2010 6:02 pm
If you could file the gusset, without affecting the tube underneath, would it work?
Posted : 26/08/2010 6:04 pm
If money is tight, can you remove the adjusters on the fork until you get another headset?
Posted : 26/08/2010 6:06 pm
I'm using a Hope step down on my Mmmbop with Pikes, the floodgate adjuster just tickles the gusset on the downtube.
I've got a deeper lower cup that I could put in but I think I'll leave it as it is.
My mate had the same problem as you, (don't know what headset) he just filed a bit off the gusset.
set the rebound and remove the dial
Posted : 26/08/2010 6:12 pm
Indeed I did. My headset was an FSA Orbit Z 1.5 reducer - this one...
[url] http://www.chainreactioncycles.com/Models.aspx?ModelID=10125 [/url]
The floodgate adjuster on my Pikes caught in exactly the same place. I just filed a bit of the gusset away. No big deal really although it does feel a little wrong on a new frame. Just make sure you protect the rest of the downtube with something in case you slip.
Thanks for all the speedy replies. Much appreciated
@RSE It juuust catches on the tube too. Im not too keen on filing - kinda feels wrong!
I guess a new headset is required. Any suggestions for the cheapest out there? Sorry, Im totally new to all this. Im a snowboarder who's branching out beyond just commuting
[IMG] http://www.darksnow.co.uk/g2/main.php?g2_view=core.DownloadItem&g2_itemId=3613&g2_serialNumber=1 [/IMG]
Posted : 26/08/2010 6:23 pm
in exactly the same place as your last photo with a previous bike and ran it for years with the rebound adjuster off and filled down the lockout adjuster
Posted : 26/08/2010 6:27 pm
Yeah, DON'T file the tube!
I have a BNIB Hope Stepdown headset that would do the trick. email in profile if you're interested.
Posted : 26/08/2010 6:31 pm
 IA
I'd just file the adjuster down a bit. Or take that off too.
Posted : 26/08/2010 6:33 pm
Am I missing the point in which this is an issue?
Unless you are doing bar spins, surely just being careful is OK and maybe a thick bit of helicopter tape on the point it touches just in case you come off and it trys to spin around.
Posted : 27/08/2010 12:42 am
