Headset fitting que...
[Closed] Headset fitting questions
[#3751116]
Ok, so i have my shiny new Cane Creek S8 headset but no dedicated tools to fit it with. Making a press won't be much of a problem, a few minutes in work tomorrow with a length of 8 or 10mm threaded bar, a couple of nuts and washers and two good pieces of model board will make that easily enough.
However, i don't have the removal tool. I could use a screwdriver to tap it out but i'm worried about scoring the inside of the headtube plus wrecking a good screwdriver.
So, what bodges have you lot come up with?
Any tips on fitting as well would be helpful 🙂
Posted : 07/03/2012 8:12 pm
plastic pipe, cut half way up so its splayed into 4 pieces with a bung wedged in it (like a cork or something) to hold them apart.
bash away with no risk of scoring.
Posted : 07/03/2012 8:26 pm
have you got a piece of pipe lying about that fits. I've used 22mm copper(mainly as that was in the garage), cut an X in the end (two 2" cuts at right angles, splay ends till they mate to bearings and tap out.
Posted : 07/03/2012 8:28 pm
I'm 'hoping' that the guys in the maintainance shop will have some old bits of pipe i can scavenge, i'm baulking at paying the best part of twenty quid for something similar!
Posted : 07/03/2012 9:03 pm
