Very nice – not seen these before but just checked out their website.
If you were only going to consider a 100mm fixed travel fork then the justification for a new fork would be minimal. Damping technology has got better recently so you would certainly feel the benefit from a that perspective. Simlarly, if you ended up with a 15mm or 20mm axle you might well feel that benefit, although for light trail riding it might not be entirely justified.
However it looks as thought the Sirus, (this is the frame you've ordered righ?) can take anything from a 90mm to a 130mm fork. On that basis, it would be worth buying a fork that can be adjusted between these ranges, which would then give you the choice of how the bike handles/performs. Run them at 100mm for general all round use, then up them to 120mm for Welsh trail centres.
The new Fox 32 Talas or maybe the RS Revelation/Reba would be good choices as you can adjust the travel on these.
What colour did you end up ordering then?
