[img] http://s22.postimg.org/o6g69q229/final2.jp g" target="_blank">
http://s22.postimg.org/o6g69q229/final2.jp g"/> [/img]
If you've got an Edge 800 you'll know that the basemap is useless, and that the official Ordnance Survey Discoverer map is OK, but expensive and cluttered when zoomed in.
TalkyToaster did some good work taking OpenStreetMap data and presenting it in the Ordnance Survey style. I've done something similar, except I've tried to make it a bit clearer (wider tracks and roads, brighter colours etc), and more importantly, I'm not charging for it.
This is my first foray into Garmin mapping so I'll try to update this image as I get more familiar with the map creation tools. The map below is based on the most up-to-data OSM data.
Huge thanks to Nick Pinn for starting me off with [url= http://pinns.co.uk/osm/ ]his OS-style type file[/url] and providing helpful support by email.
[i][b]Download link and installation guide below the screenshots.[/b][/i]
[img] http://s22.postimg.org/yqq3sb6k1/final4.jp g" target="_blank">
http://s22.postimg.org/yqq3sb6k1/final4.jp g"/> [/img]
[img] http://s22.postimg.org/po1mla6sx/final6.jp g" target="_blank">
http://s22.postimg.org/po1mla6sx/final6.jp g"/> [/img]
[b]Download (~400MB):[/b]
https://www.dropbox.com/s/n5w3h68add8hmk1/OS50.img
[b]Installation:[/b]
Copy directly to your Edge 800's memory card. I see no reason why this shouldn't work on the 810 or Touring.
[b]Enable the map:[/b]
Go to Settings -> System -> Maps and make sure it's enabled. You might want to adjust the detail level as it can get a bit cluttered on levels above "Medium". I'm aiming to fix that it in the next release.
[b]Notes:[/b]
OpenStreetMap data is good but is missing the odd path. It's also not verified and subject to error. Relying on this as a sole navigation source is foolish at best and reckless at worst. That being said, I've not encountered a problem.
Cheers, I'll give these a whirl today. 🙂
Awesome, I see Nick's rebuilt his OS50 style file. I was using the previous version but they were a bit buggy. I'll try recompiling with the new version 🙂
My maps don't have contours yet, that's the next step.
Nice one I'll download these later on and give them ago, normal openstreetmap is a bit difficult to see on the edge 800 screen.
Thank you very much. I've the TalkyToaster ones but will give these a try too
Do you find contours useful on the Edge? I thought they cluttered the map, which is why I left them out.
Cheers, downloaded and will try on my Touring Plus later.
Nicely done- will try them out.
Cheers, Paul
Great work Flaperon. I contacted the guy from talktoaster to ask how to create the garmin files from raw data, he did not respond. Is it relatively easy? As I have managed to create gradient lines (chevrons) and NCN overlays for OSM but not yet got round to garmin'ising it.
Also, massive chapeau for not charging for it.
For Touring Plus map enable it's
Settings/Trip Pages/Map/Map Information Select Map
Nice work 🙂
FWI I find contours useful as I then know how much further I have to gasp my way up climbs I don't know well.
Anyone know if this will work on a 605?
Looks good, I'll give it a go!! Nice work
Cheers will give it a try in a couple of days. Tried navigating soton to Banbury yesterday, very frustrating with openstreetmap
Cheers will give a try...
Looks like Dropbox has thrown a tantrum over the data usage. Will try to find a new home for it tomorrow.
Top work & thank you. Are all Edges the same? Should it work on my Etrex 20?
Will I be able to down load and install this using an imac. Looks good.
yes. I renamed it "gmapsupp" as according to the manuals thats the .img file name the etrex needs to recognise it, and its currently installed via the microSD card in my Etrex20.
Havent had chance to use it yet but cheers to the OP.
@2002
Yes, exactly how I did my unit earlier today.
Nice. Can you do the same for Germany?
@Roter Stern - yep, should be able to but will need to find somewhere new to host the files since Dropbox is limited to 20GB/day.
Speaking of Dropbox, the link should be working again now.
Cheers, I'll give it a go today, with a ride thrown in.
Do you put the map into a new SD card or does it need to be on the one that comes with the Garmin?
Cool!
I like it, the maps my 800 came with were pants by comparison
for numpties like me, put Flaperons map into the same place as the maps on your SD card, then deselect the other maps from within the Garmin.
easy.
Thanks for the effort and link. Will try here too on my 800.
I've just tried sending this to my Touring and I need another 322 MB of memory.
Will I have to buy another SD card and put these maps on that ?
Simmy- does your touring have OS maps on it?
You may need a larger card if so.
I picked up a 16gb card, and then moved the OS maps onto it, and all the others.
The menu then allows you to select the appropriate map.
I believe you can also attach a map to a bike profile.
P
Simmy make sure you copy the file to the memory card not the memory on the unit.
Just bookmarking for later
Think I've got it sorted now, it's appearing in the map options so I've just sent a previous ride to the Touring so now time to try it out.
Will report back all being well 😀
Worked fine for me on my ride this morning.
Cheers Flaperon
would this work on a GPS60 CSX?
Probably not, unfortunately.
Where am I going wrong with this? I've downloaded the Dropbox file and put it onto a new memory card, but it looks nothing at all like the screenshots on here. I've tried altering the level of detail on the maps, but it makes no difference.
If it makes any difference, when I tried to open the file before putting it on the card, it said it was corrupted.
Try downloading it again? If you're copying it to a brand new memory card, let the Garmin initialise the card before copying it over to the "Garmin" directory.
If you're putting it in the root directory of the card, it probably won't work. Should amend the instructions, really!
To be absolutely clear, it needs to be in the \Garmin\ folder on the card.
Thank you very muchly, much appreciated!
I have spent the weekend trying to get my head around this Garmin mapping system. Are you able to clear a few things up for me please?
So the gmapsupp.img is a map, correct? When I select and add maps with MapInstall, how does this differ from just copying the .img file directly to the sd card?
I can choose between the maps I've added with MapInstall on the Garmin's menu. How do I choose between the .img files I've added? Surely as they have the same name only one is allowed on the sd card?
Thank you again for the maps, will try them out tomorrow. And thanks if you are able to clear up my badly worded questions above!
I've downloaded it a few times and tried it, but it's always the same.
Its obviously me, cos I'm hopeless with this kind of thing.
As for putting it in the directory or garmin folder, how do I do that.
Here's what I did, downloaded it, put my new card into my laptop, right clicked on the Dropbox download, send it to new card.
There's no mention of directories or folders or anything.
I need a real idiots guide to things !ike this, which is incidentally why I'm using a new card so I won't bugger the original one up 😆
I've only gone and bloody done it 8)
And quite easy once you know how.
Many thanks,look forward to trying it this week.
so talk us through how you did it houndlegs
Well originally I was just sending it to my new card by right clicking and sending.
I never knew it had to go in a folder- I know very little about computers apart from internet browsing-I didn't even know how to open my new card to see what was on it, so I had a little dig about the internet and found out how to open it, and hey presto there was my garmin folder and ahem 😳 four lots of Dropbox downloads from where I just kept sending them lol.
It was just a matter of dragging one of them to the folder and that was it, and deleted the rest of them. I'm assuming the garmin folder was set up because I'd put the card into the garmin, so I didn't even have to make a folder, which was good cos I've never done that either 😀
They look good - currently downloading - thank you!!
I'm interested in giving these a try, but can't get at the dropbox link. I have previously been using the maps from garmin.openstreetmap.nl .
I can probably help with the hosting. I run an ISP and we're happy to donate bandwidth to good causes. Drop me an email and we can sort something out.
Just taken a look on the 800 - looks really nice! Much easier to read.
Question (I don't know much about the 800!) is the map 'routable'? I treid for the first time to follow a route on Friday and it said it was unable to route. Apparently this is due to the base mapping? I was using openstreetmap off talkytoaster
THE DROP BOX THING DOSENT WORK. ANY CHANCE OF GETTING IT FIXED. PLEASEEE
I'm uploading my version of the Garmin British OSM maps to google drive currently, I'll link to the download when done.
Should effectively be the same as Flaperon's
Edit: Here you go
https://drive.google.com/file/d/0B_uy0wF5v0lbNjEtb0ZOM1BFR2c/edit?usp=sharing
Hope I'm not treading on the OP's shoes 🙂
