[url= http://monkeylikeshiny.blogspot.com/2010/01/sprocket-brake-for-your-fixie.html ]Fixie disc brake[/url]
This is basically going to snap your legs off mid shin innit?
why would it do that?
its a brilliant (if slightly crazy) idea
Surely you will have to run the chain unlubricated or it will just not work?
That does seem an answer to a question no one asked. Although I don't think there are any fixed disc hubs.
I'll add that I think it's brilliant that people do these types of 'shed' engineering though.
Good point TJ.
Assuming sufficient friction it wouldn't snap your legs any more than having a front brake sends you over the bars
Bit of panic braking amd the cranks stop, your legs don't, pedals in the shin?
Although if your using disco slippers I guess this wouldn't happen, I forget that some people like being screwed to their bike!
ATK tried this kind of setup on the MX bikes in the 80's
They also used their A Track system which was basicly a pair of rollers above and below the drive sprocket that elimanated back end squat. I see some freeridey type bikes are now using the same system to elimanate bob.
Nothing's new, just re hashed.
[i]I forget that some people like being screwed to their bike! [/i]
Never ever try riding fixed on flats!
fixie and clips all the way
Hang on, I run a fixie mountain bike with discs front and rear.
The rear hub is just a normal Phil Wood with a bit of loctite on the thread.
The pedals are flats (DMR V12s).
I only really ride it off road and have only had a couple of 'moments' when I have lost the pedals and that was when I was glad I had a brake.
The whole fixie is difficult/dangerous is a myth.
