Fitting full length...
[Closed] Fitting full length mudguards with disc brakes
[#3494146]
Looking to fit some full length SKS mudguards to my Hybrid (Specialized Crosstrail). Rear should fit fine as the caliper fits between the seat/chain stay, so the mount has plenty of clearance. However, it looks like the front brake caliper may foul the mounting bracket/arm. Anyone with any advice to get around this, or is it a case of just bending it into place?
Or are there any mudguard sets that are designed to work with discs?
Posted : 26/12/2011 5:24 pm
The says on SKS mudguards are plenty long enough to allow you to bend them in my experience.
Posted : 26/12/2011 5:27 pm
Fit them at the fork end first. Bend around to clear brake then trim as needed. Thats what I do.
Posted : 26/12/2011 5:32 pm
i use the brake mount front and back to mount the mudguard, slightly longer bolts and attach to the top bolt on caliper. works a treat though i now have uneven length mudguard braces so they won't work on any other bike
Posted : 26/12/2011 5:37 pm
As above - just bend them to fit. You should be able to see what I did to my rear stay in this photo.
[url= http://farm7.staticflickr.com/6070/6032054553_ece16ca8cb_b.jp g" target="_blank">http://farm7.staticflickr.com/6070/6032054553_ece16ca8cb_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/druidh2000/6032054553/ ]2010-04-13 23-45-11[/url] by [url= http://www.flickr.com/people/druidh2000/ ]druidh_dubh[/url], on Flickr
Posted : 26/12/2011 5:43 pm
Thanks for the suggestions
Posted : 29/12/2011 1:57 pm
 hels
Are you planning on using the bike offroad ? I witnessed an incident a few years ago where a chap took his commuter bike around the red at GT with a learner group, full mudguards. Rock went inbetween the wheel and the guard, jammed it to a dead stop and he flew off at speed. Not a good idea, or could have been a freak accident, you decide.
Posted : 29/12/2011 2:12 pm
SKS ones come with a safety front mount that unclips itself if something gets jammed. (probably concertina's your expensive mudguards, but better than this ^ )
Posted : 29/12/2011 2:17 pm
On my hybrid fork there's a mudguard mount above the brake mount higher up the leg. I just needed to cut down the stays to fit. P clips in the right place would do the same thing.
Posted : 29/12/2011 3:41 pm
[i]Are you planning on using the bike offroad ? I witnessed an incident a few years ago where a chap took his commuter bike around the red at GT with a learner group, full mudguards. Rock went inbetween the wheel and the guard, jammed it to a dead stop and he flew off at speed. Not a good idea, or could have been a freak accident, you decide. [/i]
Mainly back country lanes, odd bit of canal towpath. Food for thought though... 😯
Posted : 29/12/2011 4:21 pm
