Electrical transfor...
[Closed] Electrical transformers current/voltage ratio - remind me
[#4193477]
It's been a while since A-level (or maybe it was GCSE) physics...
Am I right in thinking that the ratio of the currents and the voltages on either 'side' of a transformer is the same?
Say, for example, you have a 240V input transformer, with a 12V output into something that draws 4A. The ratio of the voltages is 20/1, so would the ratio of the currents be the same, so the draw on the input side would be 4/20 => 0.2A?
Posted : 25/07/2012 9:52 am
Roughly speaking, yes. Power is your constant (VI), ignoring some of the complexities of inductive/reactive loads. Decreasing voltage requires a step up in current to maintain the same power throughput.
Posted : 25/07/2012 10:07 am
Smashing, thanks.
Posted : 25/07/2012 10:19 am
