DT Revolution spoke...
[Closed] DT Revolution spokes- how 'fragile' are they? Any heavy riders?
 hora
[#1736574]
Any experiences and do you need to avoid really if you are weighty or ride rocky trails?
Posted : 24/06/2010 1:51 pm
Revolutions?
Posted : 24/06/2010 1:52 pm
 hora
Oops corrected!
Posted : 24/06/2010 1:55 pm
i have dt 4.2ds on 240 hubs built with revolutions, i am 6,3 & 16st never had any problems. Built by that roger musson fellow who said its more to do with the build quality when i questioned the weight issue.
ridden all sorts on them and they've never even gone out of true in 3 years so far
Posted : 24/06/2010 1:58 pm
i run them on dt 4.2 rims and xtr hubs.done numerous races including transwales.managed to crack the rim all the way round but didnt break a spoke .
Posted : 24/06/2010 2:19 pm
Specialized specced them as standard on the 2005 Enduro, the first year it went 'burly'. They're a lot tougher than folk give credit for, definitely all about the build quality!
Posted : 24/06/2010 2:21 pm
 GW
avoid if you are heavy or ride harsh!
they're not going to snap but they do build a flexy high maintenance wheel no matter what Roger Musson says.
Posted : 24/06/2010 2:43 pm
Depends on many variables. Not as tough as competitions but many get away with simlar maintenance.
Posted : 24/06/2010 2:44 pm
true enough, I'm building my next set with competitions, well sapim equiv. and with hindsight i tend not to use the dt wheels for anything too heavy duty now
Posted : 24/06/2010 4:09 pm
If you're a rough rider, I'd avoid them... similar approach for sapim lasers.
If you want a tough built and very light wheel, I'd look to Sapim CX-Rays. Super strong, super light. Strongest spoke available and lighter than revs and lasers.
Currently getting a set of wheels built up with CX-RAYs as we speak.
Posted : 24/06/2010 4:16 pm
The same weight as Revs actually, if not very slightly heavier, although they do have a very high fatigue strength yes.
I've had 3 sets of wheels with CX-Rays, but wouldn't bother again, too much faff/expense for too little benefit IMO. Don't let that put you off your wheels mind!
Posted : 24/06/2010 4:23 pm
Barely any lighter and just as flexy.
Posted : 24/06/2010 4:24 pm
Ah yes, I didn't mention that, but they flex just as much as Revs/Aerolites.
Posted : 24/06/2010 4:28 pm
had a set built by merlincycles a long time ago. they were fine for me on all sorts of terrain but i would now say pointless unless your racing, even then maybe not any real advantage. i recently built a wheel using them and they are hard to work with due to spoke wind up. i don't think i'd build a wheel with them again, i would try to save weight on the rim and tyre and use dt comps.
Posted : 24/06/2010 4:34 pm
Built my last wheel with CX-Rays (just because) can't say I've noticed a massive difference over the DT I'd normally use.
Posted : 24/06/2010 4:36 pm
Slight aero advantage of bladed spokes on the road, no real advantage on the MTB.
I've broken several nipples too, which has exactly the same effect as breaking a spoke, but can be very slightly easier to remedy! By making the spokes stronger you merely shift the issue to the next week link.
A lot of the German shops doing good deals on wheels still use them, they've never been all that popular over here.
The wind-up can be a real problem, particularly once the nipples have seized solid onto the spoke! You get tools to hold them still, but it's still an extra faff!
I have used them for years without problems (6.2" 11 and a half/12ish stone)
As mentioned above, all about build quality not what you build them with (too a degree, wouldn't say do DH on a XC wheel) but I have had some standard/stock wheels that I have broken though sprinting and then had superlight race wheels that have done everything without bating an eyelid. Find a good wheel builder and you will be fine, a bad build and you will have endless problems...but thats the same whatever spokes you use.
Posted : 24/06/2010 5:36 pm
