Drilling a 33mm hol...
[Closed] Drilling a 33mm hole in a kitchen work top - How?
[#2962890]
How do I drill a 33mm hole through my kitchen work top to accept the air switch button for the waste disposal?
It needs to be neat and work with a standard drill.
I am guessing I start with a small pilot hole but what will get up to 33mm without wrecking the worktop?
Posted : 19/07/2011 4:28 pm
Hole saw/bit thingy.....
Like this:
Not expensive, available at any DIY store
Posted : 19/07/2011 4:29 pm
Surely depends on what the worktop is made out of?
Posted : 19/07/2011 4:30 pm
as druidh says - and how neat it has to be IE are the edges going to be visible of covered
Posted : 19/07/2011 4:31 pm
Yes, but if it's granite or similar that has to be professionally fitted, they will do it for you. 🙂
If they don't, or you forgot...... Ooops!
http://www.diynot.com/forums/viewtopic.php?t=254314
Posted : 19/07/2011 4:33 pm
Yes we forgot - oops
Only chipboard - whoopee
Posted : 19/07/2011 4:34 pm
A 33mm hole saw or:
drill a series of small holes inside a 32mm scribed circle and finish it with a file or a rotary burr or:
Scribe a circle, drill a hole, cut around the circle with a jig saw with lots of to and froing to stop the saw jamming or breaking on such a tight circle.
Posted : 19/07/2011 4:35 pm
Sorted then.
It's a piece of cake with one of those cutters, don't be tempted to try and do it without though! Not worth the bother for a £5-ish tool which just works, and leaves a very neat clean finish 🙂
Happy to buy the bit. just couldn't find one on line. All the hole cutters seemed to be for tiles.
The only wood one I found was at Screwfix for £20
http://www.screwfix.com/p/dewalt-self-feed-bit-32mm/54109
Posted : 19/07/2011 4:38 pm
I see what you mean....
I got a set in the box with a set of drill bits years ago. Mine are only cheap ones but they work brilliantly and I've used them several times...... Just go to the store and ask. 🙂
Posted : 19/07/2011 4:42 pm
Just google "hole cutter set" there are loads
Posted : 19/07/2011 4:43 pm
Google 'Hole saw', not cutter
Posted : 19/07/2011 4:44 pm
Dont know if they had the size you need but Aldi were selling them on Sunday
[url] [/url]
[url= http://www.screwfix.com/p/bosch-cobalt-holesaw-32mm/36439 ]http://www.screwfix.com/p/bosch-cobalt-holesaw-32mm/36439[/url]
Posted : 19/07/2011 4:45 pm
you cant just cut through 30MM of chipboard in one go. youll need to remove hte saw a few times to get the crud out otherwise you get a fire from teh friction... ive not experimented... 😀
Also cover the area with masking tape... It'll help stop the laminate from chipping (and make it easier to mark the holes position!).
Posted : 19/07/2011 4:47 pm
A flat wood bit will do the job perfectly fine and should only cost a couple of quid, as has been pointed out a hole saw would not be deep enough to cut through, you would have to stop, remove some of the core then continue. A flat wood bit will remove the waste as it cuts. a small pilot for the bit to sit in as you start to drill will help.
Posted : 19/07/2011 4:54 pm
Noshki is spot on.
You probably won't find a 33mm flat bit but you will definitely find a 32mm one in most builders merchants as they are used for drilling a hole for a 'Yale' lock in doors.
32mm will probably do as i can't imagine the 33mm is a dead tight fit as they usually allow a bit of tollerance
Posted : 19/07/2011 5:50 pm
Or you can just buy one tool that will do a whole range of hole sizes for future use:
http://www.screwfix.com/p/expansive-bit-22-76mm/40440
Posted : 19/07/2011 8:24 pm
I wouldn't rely on a hole saw making a clean cut.
The saw teeth are angled and will lift the laminate as they cut, breaking it away, leaving a rough edge.
A router is the only sure way.
Posted : 19/07/2011 8:33 pm
It is done. the 35mm hindge bit I had did the job as the button surround covered the hole. Yes the plastic coating chipped so I wish I had read about putting tape over it but it doesn't show.
Thanks for the advice
Posted : 19/07/2011 9:20 pm
