direct me to a plac...
[Closed] direct me to a place to buy the bendy metal things that go under bar tape
[#8089591]
need to get hold of 4 of the brake / gear bendy spiral metal things that go under the bar tape from the shifters on road bikes, can i buy these on their own?
apologies in advance for the numpty question
Posted : 04/10/2016 8:31 am
eh? nothing* under my tape
*do you just mean short length of cable outer ? 😳
Posted : 04/10/2016 8:34 am
 LeeW
You mean the hoseclip style fixing strap?
Posted : 04/10/2016 8:37 am
Is that a convoluted way of saying handlebar?
Posted : 04/10/2016 8:38 am
I think I know what you mean although I have only seen plastic. Like a string of upside down plastic U shapes linked, to smooth off the rounded profile of the cable outer
Posted : 04/10/2016 8:43 am
Do you mean these?
[url= https://www.sjscycles.co.uk/cables/flexible-v-brake-guide-pipe-90mm-long/ ]V brake noodle[/url]
I've only ever needed them when fitting bull bars because of the extreme cable bend...
Posted : 04/10/2016 8:48 am
I know what you mean. Not seen them for years and I've never used them. I have some In the garage if youre desperate I could look out.
Posted : 04/10/2016 8:56 am
 5lab
posh brifters route cables under the bar tape, cheap ones dont. I dont think you can convert them?
Posted : 04/10/2016 9:04 am
think mrs antigee's specialised (105) has some sort of plastic section strapped to the handlebars and then as exits tape switches to normal outer - I would just fit normal outer all the way - never seen it for sale even in the oddest long tail corners of the bicycle parts darkweb, my guess is its an easy factory fit and does the job
for shimano Tiagra and higher now have both sets of cables exit under the tape (99% sure) you can't convert them 100% sure
Posted : 04/10/2016 9:42 am
Most people just run cable outer to the lever and then tape that to the bar before the bar tape itself goes on?
you don't get a 'lump' where the cable outer is on the finished bar tape - just put it somewhere the shape feels comfortable.
Posted : 04/10/2016 9:46 am
Im assuming he means brake / gear cable outers.
Posted : 04/10/2016 9:54 am
 pdw
These things?
http://jagwire.com/products/small-parts/ez-bend-housing-segment
Those are supposedly for brakes. Don't know of an equivalent for gears.
In general, they're not necessary, but I had a battle with some SRAM hydraulic shifters that have the cable exit at a stupid angle, and if you tried to route it with normal gear outers you'd get a lot of friction due to the tight bends. I eventually solved it by using a short section of brake outer to get it around the bends.
Posted : 04/10/2016 10:05 am
nope, if im right its a bit that fits over the cable outer. mine came with a set of 7700 duraace shifters.
the plastic/white bits in the pic above
Posted : 04/10/2016 12:29 pm
aye, I thought they meant the white bits. I tried them and they made the bar too wide for me but still had a lump like with cables
Posted : 04/10/2016 12:38 pm
I've thrown away (literally) dozens of those. One of the most useless ideas ever. They aren't even needed with old school bar tape.
Posted : 04/10/2016 1:06 pm
wow, didnt think that was goig to get such a response. i should have made it clearer. I have nokon cables and these section are the ones pdw fired the link to. Not sure if they have a name but nokon do spares:
https://www.bike-components.de/en/Nokon/Schalt-und-Bremswendel-fuer-Rennrad-p21532/
cheers all
Posted : 04/10/2016 3:29 pm
Isn't it easier to replace cable outer if you use these?
Posted : 04/10/2016 4:12 pm
Well, I was way off.
Posted : 04/10/2016 8:24 pm
