Decent bike mount f...
[Closed] Decent bike mount for Garmin Oregon?
[#6147123]
Any recommendations as the Garmin mount is not very secure?
Posted : 27/04/2014 6:55 pm
Can't offer an alternative as I use the garmin version. I agree that it's not the best mount ever made, but I've never had a problem with the head unit working loose, if anything I've found it a bit tight. The only issue I've ever found with it is a tendency to slip a bit. I solved this be adding some extra rubber under the cable ties to provide a bit extra grip.
Posted : 27/04/2014 7:10 pm
The Dakota one is equally bad. Helps if you build up the back of the unit with some duct tape to get a tighter fit. And maybe use some sort of lanyard.
Posted : 27/04/2014 8:44 pm
Dakota and Oregon use the same mount. I've only had the Oregon eject once but I don't think it was in right anyway. Always have a lanyard on too though.
Posted : 27/04/2014 8:46 pm
I put some extra glue along the rails of the mount to make it more secure (and use a lanyard around the bars):
[url= http://www.aidanharding.com/2012/02/how-to-fix-a-garmin-dakota-bike-mount/ ]http://www.aidanharding.com/2012/02/how-to-fix-a-garmin-dakota-bike-mount/[/url]
Posted : 27/04/2014 8:47 pm
I use a couple of very small cable ties to attach the unit to the mount (in addition to the standard clip). I have to agree the amount doesn't appear the securest of mounts
Posted : 27/04/2014 8:50 pm
I use one of these - very secure mounting - gps has never come out
http://www.rammount.com/mount/garmin_oregon_mount.htm
Note : I did modify the mount by drilling some holes in the section on the bottom of the mount to put zip ties through to secure it to my bike
Posted : 27/04/2014 10:04 pm
I have the standard one, just held to the bars with two cable ties
My Oregon has never ejected, its surprisingly stiff trying to get it out. I always larks foot the lanyard around the bars just in case though
Posted : 28/04/2014 10:51 am
