Crank arm weights
[Closed] Crank arm weights
[#3786573]
Just the arms...anyone got the figures on the following?
SLX
XT
XTR
Middleburn RS8 X-type [url= http://www.middleburn.co.uk/cranks_rs8_&_rs7.php ]406g for the RS8 square taper[/url]
I'm looking to swap out the Deore on my HT, going 1x10 at the same time, while keeping it as light as I [i]reasonably[/i] can. I suspect they're all fairly close, certainly too close to to make a blind bit of difference to me...but I might be tempted to ignore the obvious (SLX) an spend a bit more for light weight [i]and[/i] bling.
Ta,
R
Posted : 19/03/2012 10:42 am
 br
XTR 960 175mm arms are 532g, tensioner and Ti bolts are another 10g.
Posted : 19/03/2012 10:47 am
KCNC?
Posted : 19/03/2012 10:53 am
Hmm...XTR is seems heftier than I expected, although I don't really know what I expected!
Thanks for the KCNC suggestion, but I'm gonna keep it mainstream.
Posted : 19/03/2012 12:34 pm
Why mainstream? KCNC do some great products
Posted : 19/03/2012 1:25 pm
SLX 175mm i have as 597g. The double and bash versions are heavier.
Posted : 19/03/2012 1:41 pm
Be carefull to compare properly.
Crank arms with/without nuts and bolts can be nearly 40g different.
XTR usually had alloy nuts and bolts, XT a mixture and SLX all steel.
Scamper is right about SLX double and bash because of thicker arms and steel pedal inserts.
PaulD
Posted : 19/03/2012 1:47 pm
XTR is seriously stiff though, great power transfer.
Posted : 19/03/2012 5:24 pm
also add the BB weight when comparing with square taper as HTII BBs are a lot lighter.
tbh there is not much in it. Choose whatever you prefer the look of as you are probably talking less than 100g between SLX and XTR with XT in the middle.
Posted : 19/03/2012 5:28 pm
hollowgram? blingy cost - nice simple style too
Posted : 19/03/2012 5:40 pm
Yep, an XT BB is circa 90g, the Octalink i think was over 300g
Posted : 19/03/2012 5:57 pm
Hollowgrams are ace (though pricey). Amazingly light and stiff and you can fit whatever spider you want. 280g for the crank arms (that's both of them!)
Don't think they'll work unless you have BB30 though.
Posted : 19/03/2012 8:15 pm
You're really bothering about crank weight?
Like really?
Posted : 19/03/2012 8:18 pm
Middleburn X type 175mm cranks c/w 5 bolt spider ( approx 60g ) = 610g
need to add rings and bolts to this.
you could go for a uno ring if going 1 x 10
my set up with 20,30 bash and alloy bolts = 782g complete
Hope X type bottom bracket = 109g
2012 SLX FC-M660 24,32,42 = 812g complete
SLX / XT bottom bracket to match = 90g
Posted : 20/03/2012 12:17 am
Like really?
Why not! One of the heaviest parts of the bike!
If you had Hollogram money I'd get Lightning.
If you sell the rings on XTR you can recoup a significant proportion of the cost, I did that with some M970s. XT rings fetch less, narrows the cost gap.
Posted : 20/03/2012 12:27 am
I swapped cranks recently, & in terms of arm weight alone, there wasn't a lot in it between Deore "HT2's" & XT M770's with proper hollow arms. The XT's are much stiffer though.
Posted : 20/03/2012 9:28 am
Thanks all.
Shorty121 - Member
I'm sure they do, but I've had a look at their cranks and didn't see anything to get too excited about.
andyl - Member
The Middleburn square taper weight is up there simply because its all they have on the website. I know that BB type, spider and rings will all play a part, which is why I'm querying arm weight only.
pjbarton - Member
Hadn't heard of these...ooh, they're lovely but the price is, ahem, prohibitive!
crikey - Member
Like really?
Am I bovvered? No. Curious, yes.
njee20 - Member
One of the things I'm considering and its only this that brings XTR into the equation really.
So, at the moment SLX is [i]very[/i] tempting @ £99 with CRC, plus the £17 offer bringing it down to £87. That's it, I'm decided. Pretty much. Either that or XTR and sell the rings. Or wait for another CRC 10% offer and get Middleburn + Uno, cos it's sexy.
Dammnit!
Posted : 20/03/2012 9:59 am
Ive got some m711 XT cranks with BB and 34t ring if your interested for £60? Emai; kh306(at)exeter.ac.uk
Posted : 20/03/2012 10:08 am
included the weight of the hollowgrams with a BSA adapter
Posted : 20/03/2012 10:18 am
dr, superb info...thanks! Disappointing there's no Middleburn though...must try harder next time 😉
RaceFace, decent weight saving and look great, but waaay too dear for me with no decent offers on.
Shimano are all pretty close, just goes to show what good value their cheaper cranks are, I couldn't justify over 3x the price for XTR on weight alone...what is that, 2.5oz over SLX in real money?
Cheers,
Posted : 20/03/2012 11:37 am
Posted : 20/03/2012 11:44 am
[i]swoon[/i]
Posted : 20/03/2012 11:53 am
