Comedy crash-tastic...
[Closed] Comedy crash-tastic.
[#7859331]
Invisible log causes Camelbak crash:
This doesn't count as a crash does it ? I held it right to the end 🙂
Posted : 31/05/2016 8:10 am
Funny. What happened?
Posted : 31/05/2016 8:17 am
I endowed over that massive invisible log at the start of the trail. Sat on the stem and got the saddle caught in my Camelbak !
I see now why Enduro types use bottles, Camelbak's are bloody dangerous 🙂
Posted : 31/05/2016 8:20 am
That was actually hilarious, thanks.
Posted : 31/05/2016 10:02 am
29er would have rolled over that no issue.
Were you trying to match this?
Posted : 31/05/2016 10:09 am
Is this the bikepacking i've heard so much about?
Posted : 31/05/2016 10:17 am
If it wasn't for that handy tree to grab I would probably run the whole trail on my tip-toes.
I still struggle to figure out how I ended up sitting on the Stem. New bike trying to kill me ?
Posted : 31/05/2016 10:43 am
Special in every way 😆
Posted : 31/05/2016 10:47 am
Trimix - Member
I endowed over....
Well tuck it in to your sock next time instead of dragging it along the ground catching on things.
And good work for sharing!
Posted : 31/05/2016 12:26 pm
Hee hee - I've done something similar a few times.
Slightly differently I was flying down a local trail a long time ago and rounded a fast corner to find the upper branches of a fallen tree laying across the track. Too late to brake I braced myself and rode through it and survived.
On retracing my steps I found the bungee webbing from my camelbak still hanging off a branch and the scrunched up waterproof I had in it about ten yards away in the undergrowth. Could have been a lot, lot nastier. 😳
Posted : 31/05/2016 12:52 pm
 D0NK
looks like your rear wheel hooked up on a root throwing your weight way over the front, hello endo-city, extra points for getting your saddle hooked in your 'bak tho. That what happened?
I've had a few similar ish ones
Chain slipped while sprinting, weight thrown over front wheel enough to snap the cheapy front QR, ouch.
Grunting up a steep climb, rear tyre lost traction again thrown forward, ended up both hands on the floor doubled up over the bars.
Posted : 31/05/2016 1:20 pm
Anyone else stuck their arse back and then got their baggy shorts gusset caught on the back of the saddle?
Posted : 31/05/2016 2:13 pm
I did open up a pair of cheapo waterproof trousers pretty much from knee to knee on the very first climb of a solo ride in the Peaks. I got onto the first steep climb and the chain slipped on the cassette. I was in classic steep climb stance - weight on the nose of the saddle. I hit the back brake as the bike started to roll back - the nose of the saddle caught in the crotch of the trousers and ripped them open. I managed to do a sort of backwards vault over the saddle and land on my feet.
When I tried to sit back on to ride, the saddle just disappeared up inside the gaping hole in the trousers (now more of a kilt). Having driven for an hour and a half to get there I wasn't happy about the prospect of driving straight back home. So I stripped below the waist (quickly - it was around 20th December) and put my padded undershorts over the top as a pseudo-gusset.
I did the rest of the ride like that - and remembered to replace the badly worn chain and cassette as well.
Posted : 31/05/2016 2:20 pm
I take it you remembered to swap the brakes round after taking delivery of the Capra? 😉
Posted : 31/05/2016 2:31 pm
The moral is don't ride when a GoPro pointed at you.
He also has footage of me lying in the dirt having discovered just how fast you can ride round a berm 🙂
Posted : 31/05/2016 2:32 pm
I did swop the brakes 🙂
I blame it on the invisible log.
(If I ever post up riding tips can someone remind me of this footage)
Posted : 31/05/2016 2:33 pm
It's funny, but I can't fathom out how you did it - even with the explanation! 😆
Looks like this sort of thing I do.
Posted : 31/05/2016 3:31 pm
Yeah, me neither 🙂
I've had three separate skills sessions and spend ages fiddling with my suspension settings - but still fall off over nothing !
All the gear and absolutely no idea.
Posted : 31/05/2016 3:44 pm
