Checking derailleur...
[Closed] Checking derailleur hanger alignment without a tool?
[#7838808]
Anyone have any good tips/tricks for checking the alignment of a derailleur hanger without the requisite Park/etc tool?
Posted : 19/05/2016 9:06 pm
Screwing the longest bolt you can find into it often highlights how squint it is.
Posted : 19/05/2016 9:10 pm
Make a tool. Length of angle iron,a bolt, stack of washers or a spacer. and a ruler. One of the cheapest and easiest bike tools to make.
Posted : 19/05/2016 9:25 pm
Look at it closesly then reattach singlespeed wheel.
Posted : 19/05/2016 9:28 pm
Got a spare rear wheel with a threaded axle?
If so (or can borrow one), remove rear mech and thread spare wheel into hanger - it's the same thread as your mech.
Spare wheel should be parallel to your wheel - if not, manipulate hanger via spare wheel until they're parallel.
Posted : 19/05/2016 9:32 pm
I think the lifeline tool is about £20.
Posted : 19/05/2016 9:36 pm
Depends on the hanger but many have a flat side - take it off and lay it on something flat . If there's gaps its bent, if it sits flush it is straight. Of course that only works if it can lie flat!
Posted : 20/05/2016 12:07 am
Fit a mech and eyeball it. It's meant to hang downwards.
Posted : 20/05/2016 12:15 am
If you make a tool the thread is M10x1, which is finer than the M10 that tends to be sold in hardware shops
Posted : 20/05/2016 6:13 am
Only works if the dropout is perfectly flat too. Many/most aren't.
Wheel is the best "bodge".
Buying the proper tool is quick, cheap and easy.
It's one of the checks i do when the bikes get a proper service.
Posted : 20/05/2016 6:21 am
