Can a 20mm bolt thr...
[Closed] Can a 20mm bolt thru be converted to normal QR?
[#595128]
It's a Mavic Crossmax ST or would I be better just selling it on eBay with the forks?
Posted : 01/06/2009 11:56 am
some can.
Ive just changed my superstarcomponents 20mm to QR with a set of additional cups thgat you buy specific for the hub.
Maybe there's an equivalentt aftermarket thing for the Mavic hubs...
Posted : 01/06/2009 11:58 am
Yep.
Just drop the 20mm spacers out and push in the QR ones.
Posted : 01/06/2009 12:08 pm
Not on a Crossmax ST - its a different hub for the 20mm
Posted : 01/06/2009 12:36 pm
Blurb about the crossmax ST.
Mavic's close-tolerance bearing/hub interface contributes to the stability of the ST's, making the front wheel stiff for a lightweight racer when running a fork with a 9 mm QR axle, and making them stiff, period, when running a 20 mm through-axle fork. Oh, yes, these hubs adapt to either axle with included adapters that easily pop in and out of the hub shell.
Posted : 01/06/2009 12:48 pm
