Body armour for Mr ...
[Closed] Body armour for Mr Lanky?
[#2677970]
I want to get some body armour for DH riding, but at 6’5” I’ve got stupidly long ‘monkey arms'. Should I go for a full suit with the arm protection attached or would I be better with a T-shirt style suit with separate elbow /arm pads? Thanks.
Posted : 20/04/2011 9:30 am
I've been looking at this:
or this:
but can only guess at the pros and cons of each, any help will be greatly appreciated.
Posted : 20/04/2011 10:36 am
I'm only a measly 6'3" but found the back protector on 661 armour left my lower back completely exposed.
The newer designs might be better but I went to a Dainese Pro shop and tried a few jackets on - they even offered to mix and match back protector and suit size to find the best fit (I'm tall but skinny). They are a bit more expensive but if it doesn't fit properly it's not worth anything.
Also with Dainese you might find a snowboard/MX is a better fit and are all pretty similar.
Generally I prefer to keep the jacket in one piece as I've seen plenty of crashes where separate arm/leg protection rotates or slides along a limb and leaves exposed flesh to slide along the ground. Are you likely to ever ride in a jacket but no arm protection?
Posted : 20/04/2011 11:18 am
 GW
plenty taller than you ride/race DH so I can't see it being a major probem getting the correct size.. it's entirely down to you what/how much armour you want to wear. unless I'm riding uplifted I tend to wear as little armour as possible, I find even the smallest amount of armour pretty horrible to wear and I ride better without any.
Posted : 20/04/2011 11:47 am
I'm 6'4" and have a Dainese job which fits me very well. I guess the answer is to try and few on and see what fits.
Posted : 20/04/2011 11:49 am
Thanks guys, where's the best place to try some as none of my LBS's stock any and it'll be a specific trip (from Oxfordshire)?
Posted : 20/04/2011 11:51 am
 GW
Oxfordshire? 😆
break into Rob Warners garage and help yourself, he's a big lad too.
Posted : 20/04/2011 11:54 am
He'll be away in South Africa at the moment as well.
(please don't actually break into his garage though - unless you're hideously wasted at the time so that it goes hilariously wrong and you can post about it on the silly drunks thread)
Posted : 20/04/2011 12:02 pm
