Best value wide (35...
[Closed] Best value wide (35mm+) 650b rims
[#7079028]
I want to put together a semi fat bike - see previous threads and am now looking at rims to put the wheels together.
I want 3" tyres on 650b rims and it seem like wider rims are really necessary to get the benefit of the wider tyres - Flow EX (26mm ish internal width) and the like are apparently too narrow to really get the best from them.
I know that there are rims out there (Dually, Hugo, etc) but they're all pretty expensive (£100 each give or take) so I'm just wondering if there's anything else out there that I've missed that's better value (aka cheaper 🙂 ) and actually available now
TIA
Posted : 20/05/2015 2:59 pm
£ / lb I don't think you can argue with the carbon light bicycle rims. But they don't fall into the cheap category. I think they are good value, especially compared to the rest of the carbon rimmed market.
Posted : 20/05/2015 3:26 pm
I've been running a 3" tyre on a Pacenti DL31 for months with no problems.
£40 each at On-One..... [url= http://www.on-one.co.uk/i/q/RIPADL31/pacenti-dl31-rim ]Pacenti DL31[/url]
Posted : 20/05/2015 3:54 pm
Blunt 35's are cheaper
Posted : 20/05/2015 3:58 pm
Ah, thanks for that - DL31s I had found, Blunt 35s I hadn't and they sounds much more in line with what I was after in terms of price and width.
ajantom - it's not really an issue running on a narrower rim, just that the consensus seems to be that you don't really get close enough to a fat experience to be worthwhile though I'd be interested if your experience differs.
Posted : 20/05/2015 5:03 pm
No blunts in 32h 650b in stock 🙁
Posted : 20/05/2015 5:31 pm
I'm able to run the rear wheel at the same pressure as I was with the Rabbit Hole rim - about 15psi.
Had no problems with tyre roll, and to be honest it rides no differently than the old wheel.
Posted : 20/05/2015 6:52 pm
Yeah, found that but only 36h unfortunately
On the off chance, does anyone know about the Sun Ringle Mulefut 50? Looks decent for the money (£100ish) and properly wide.
http://sun-ringle.com/mtb/rims/mulefut-50sl/
Posted : 08/06/2015 8:55 am
As an update, I'm really happy with my 650b+ conversion - have any more wide (40+ mm) rims come out since that aren't £100 each?
Posted : 29/07/2015 3:48 pm
I'm riding Easton ARC 30 rims which are a 34mm external width and 30m internal. They're nice and light, build up well and seem strong so far, although they are £70-80 each.
Posted : 29/07/2015 3:53 pm
WTB Asym rims are cheaper - availability is the question.
I've had a 32h Blunt 35 on order for a while now.
Posted : 29/07/2015 4:59 pm
TBH 35mm is too small a change for it to be worthwhile for me - I have 30mm rims and they're good but I reckon a 40 / 45 on the front would be spot on.
Posted : 29/07/2015 5:23 pm
Anyone know who has stock of Easton ARC 30 650b in the UK?
Posted : 29/07/2015 7:02 pm
Has anyone found the wtb Aysm rims/whelkset in stock anywhere?
Posted : 04/08/2015 9:03 pm
Clearly wheelset not a whelkset, although that does sound interesting.
Posted : 04/08/2015 9:04 pm
Thread resurrection time - anyone seen anything new out there - 35-45mm at more like £50 than £100?
Posted : 26/11/2015 10:35 am
I found a German ebay seller doing 50mm (45mm inside) for £40posted. No idea what they are like tho. He also does them cheaper sale price but with higher postage, so may be a better deal for a few rims. Available in 27.5 and 29.
[url= http://www.ebay.co.uk/itm/391303224995?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT ]Link[/url]
Posted : 26/11/2015 10:50 am
That actually looks quite promising...
Posted : 26/11/2015 11:29 am
justridingalong have WTB asym i35s in stock for £57. I bought an i35 and an i29 from them - really easy to build - same length spokes front, rear, drive and both sides. I
Posted : 26/11/2015 1:47 pm
Hmm... wondering if a 35mm hub is really worth changing from my existing 25mm one. I'm tempted by those 50mm (well, 45mm internal really) ones though for winter and with a rigid fork (since the Purgatory won't fit in my Rebas anyway) and maybe just building up a second wheel.
Posted : 26/11/2015 5:32 pm
