Best Disc Brakes th...
[Closed] Best Disc Brakes that are SUPER light ?
[#1710997]
...and reasonably priced ? Oh, and International Standard - no extra adaptors etc.. Any REALLY good deals better than CR or Wiggle ?
I'm thinking 180 or bigger on the back and 180 on front. (Not sure my forks will allow bigger). Yes, I know the front is the MAIN stopper !
I like the look of the Formula R1's but couldn't afford them so any others only slightly heavier ??
Posted : 16/06/2010 4:07 pm
Why would you buy "super light" brakes and then fit 180 or bigger rotors?
Posted : 16/06/2010 4:10 pm
Magura Marta.
I doubt you'll find IS now.... XTR maybe?
Marta SL's in 203/180 flavour here and they are excellent, arent the formula r1 lighter though if thats priority 1?
Oh sorry reasonably priced.... you had better ignore what i said then....
Posted : 16/06/2010 4:12 pm
Formula.
Posted : 16/06/2010 4:13 pm
moon on a stick!!
no adaptors and 180mm! i think you may struggle. most callipers are now post mount and standard disc size is 160 / 140.
pancake brake is light. C 300g each.
Posted : 16/06/2010 4:27 pm
Hmmmmmm, what bike is it? If its a hardtail I'd considder a 160mm rear, that will shift a lot of weight, probably not much difference in weight between the cheepest 160mm brake and most expensive 180mm brake.
Even on a FS I'd probably try a smaller rotor, I found anything bigger locks up more easliy and so not really worh it.
Look at motorbikes, they tell you to put 70% of your effort into the front brake. Then look at the brakes themselves, 1x rear ~200mm disk Vs 2x ~350mm up front, putting >2x the effort in with >3x the power.
The usual mantra light/strong/cheep pick 2 unfortunately applies.
Posted : 16/06/2010 4:37 pm
Mmm good points about the 180's but I'm running 160's now and fancied the extra Umph ! I guess if they are better brakes 160's will do it anyway !
Any Hope's going cheap ?
Posted : 16/06/2010 4:47 pm
It's a hardtail by the way.
Posted : 16/06/2010 4:52 pm
You can't go far wrong with shimano IME, never the lightest, but usualy a good comprimise with weight decreacing the more you spend. If your not in a hurry somewhere (merlin usualy) will have sets XT's at about £125, buy some lightweight aftermarket (ashima or the same ones under 101 different brands) rotors and you'll save a ton of weight.
I'm running old 180/160 XTR's and never seen any reason to upgrade on my 456. The power isn't massive like some, but its more than enough to bring me to a rapid halt.
Posted : 16/06/2010 4:58 pm
XTR with Ashima Airotors
Posted : 16/06/2010 4:59 pm
hopes are fairly heavy, but i really like them and am happy to carry the extra weight. normally some mini's going cheap in the classifieds.
Posted : 16/06/2010 6:22 pm
light weight and 180m rotors? whats the point...learn to ride if a pro xc rider can get away with 160-140 you can because you will not be riding as fast as them.
if you want light formula r1's
look on fair wheel bikes new ultimate have released a very light brake..
....however if you want the lightest....
FRM brake drb 250
inolite rotors
4 ti bolts with thread lock
sorted
hope this helps
bruce
resident weight weenie
Posted : 16/06/2010 6:45 pm
formula R1 no brainer really. Great stoppers faultless performance and 180 disk.
Posted : 16/06/2010 7:00 pm
"because you will not be riding as fast as them"
Now wait a minute...cheers guys some good advice there. I love this site !
I'm not going to say what my brakes are at this time but one guy on here said he'd rather put his foot in the spokes than use them !!
I find them okay generally but they're not really 'trick or light'.
Posted : 17/06/2010 12:16 pm
Hope X2 Race? Sub 300 gram with rotor each end.Good back up as well! Been great on my Flux the last few months,despite what the mags say!
Thanx Max
Posted : 17/06/2010 5:07 pm
Avid XX? Second only to Saint in power according to BikeRadar's testing, and very light.
Agree on the rotor thing, light and 180mm rotors is a bit daft!
Posted : 17/06/2010 5:10 pm
 juan
well if you want that + brakes that works formula R1 are the only option
Posted : 17/06/2010 5:26 pm
 rs
surely not if you want light but also more powerful brakes.
Posted : 17/06/2010 5:27 pm
