need to order up some new goggles, general swimming use not racing and mainly pool. been using aquasphere seal for the last year but now want something smaller, not full on socket things though.
zoggs predator flex looks fave at present.
stick with aquasphere - http://www.wiggle.co.uk/aqua-sphere-kayenne-goggles/
I got these after my aquaspheres developed a leak after several years' use.
http://www.wiggle.co.uk/zoggs-fusion-air-mirror-goggles/
I think they might qualify as 'socket things' but I don't know what you mean. They're dead comfy and make you swim faster, though that second bit has not been scientifically tested.
One's that fit. Like a lot of things what's great for me isn't necessarily going to be great for someone else. I personally can't get on with any goggles that don't have an adjustable nose piece. YMMV
Only Aquasphere Kayennes work for me out of about a dozen different ones tried.
Kaimans are smaller than Kayenne.
I got some Predator Flex last summer, for similar use.
They're comfy, keep the the water out & I can see where I'm going.
They may be expensive, but I'd buy the same again.
Predator Flex fan here as well - comfy, good visibility, not silly expensive.
Speedo squidgy ones for me (I get whichever ones are about £8 or 9 quid from chainreaction or wiggle with the soft fit - current ones are 'futura ice plus').
I don't buy expensive ones, because of my careless habit of getting through pairs of goggles.
I think I have lost goggles by:
1)leaving them in hotel swimming pool locker
2 & 3)leaving them on a beach
4)my toddler bit them and destroyed the seal around the lenses
5)Mystery goggle losing event
6)The only non-speedo goggles I had the strap broke, and the strap was so tiny that other replacement straps wouldn't fit. Oh and they started fogging up really bad anywhere colder than a standard pool.
7)In a river.
One's that fit
This. One other thing to look out for is that the straps stay adjusted; I have a pair of Adidas goggles that fit well but the straps tend to come loose when wet and need readjusting every time I use them - this is such an obvious design flaw that I didn't even think about it. Some sort of ridging where the straps go through the buckles helps.
