Am i just stupid bu...
[Closed] Am i just stupid but how does this hope 1.5 reducer work
[#5259337]
So i have in front of me the 1.5 to 1 1/18 reducer cup.
http://www.merlincycles.com/bike-shop/mtb-parts/mtb-accessories/headsets-1/hope-hs136-15-1-1-8-reducer.html
Now i know this just slips onto the 1 1/8 steerer so that the 1.5 bearing can sit into this.But what happens to the seal that seals the underside of the 1.5 bearing as it seems that you now don't use either of the crown races.
Am i going mad or .????
Posted : 18/06/2013 10:03 pm
Does the 1.5 crown race not sit on top of the adaptor?
Posted : 18/06/2013 10:06 pm
You fit the adapter to the crown of the fork which increases the crown to the same as a 1.5" fork. You then fit the 1.5 crown race over the adapter and Bob's yer uncle.
Posted : 18/06/2013 10:07 pm
[quote=singlespeedstu ]Does the 1.5 crown race not sit on top of the adaptor?
+1
Reducer is a bad name for it really....
actually bulks up a 1"1/8th steerer to 1.5" so you can fit a 1.5" crown race.
Posted : 18/06/2013 10:08 pm
Sorry guys..Think iv'e just had a touch of Alzheimers regarding the race..... 😀
Posted : 18/06/2013 10:12 pm
Be careful when you go to remove it as it's made out of cheese!
Posted : 18/06/2013 10:14 pm
it reduces a 1.5" headset to 1 1/8", hence the name.
Mosey.It looks it.
Probably heat it right up before even trying to get this lump on.. 😉
Posted : 18/06/2013 10:18 pm
Yeah I put mine in boiling water and it dropped straight on. Getting it off however, resulted in one messed up adapter.
Posted : 18/06/2013 10:31 pm
 nuke
Anyone cut a slit in it to make it like a split crown race?
The crown race I'l be using is split...can't see why it would hurt to do the same to the converter
Posted : 06/10/2013 10:32 am
The reducer might be a bit more load bearing than a crown race, I'd be wary of splitting it.
Posted : 06/10/2013 12:22 pm
 nuke
Meh, got bored and went and did it anyway. Can't see how it would be more more load bearing. Worked well and it's still tight but it means you can get a screwdriver in there and tweak it on and off relatively simply. He who dares and all that 😀
Posted : 06/10/2013 12:54 pm
