980g suspension for...
[Closed] 980g suspension fork anyone?
[#5321663]
http://singletrackworld.com/wp-content/uploads/2013/07/lauf-trail-racer-fork-the-lightest-29er-suspension-fork-ever/
It's like being back in the mid-90s! 🙂
I'm loving the bonkersness.
Posted : 10/07/2013 5:31 pm
Think I will stick with sids
Posted : 10/07/2013 5:37 pm
Doesn't he need his?
Posted : 10/07/2013 5:39 pm
the suspension aspect of it looks crap but the engineering side is fantastic
Posted : 10/07/2013 5:45 pm
Looks cool, weren't RST doing something similar with elastomers and a pivot arround the steerer/fork junction?
Posted : 10/07/2013 5:47 pm
 DT78
Surely that isn't strong enough to take big hits?!
Posted : 10/07/2013 5:48 pm
DT78 - Member
Re-read the details - it's for a 29er, no big hits will be encountered hence no problem.
Posted : 10/07/2013 5:49 pm
 rob2
I shit you not, but I was sponsored by sainsbury engineering trust at uni and my tutor and I designed almost exactly the same fork as the first year project with a wound carbon spring (not leaf) and the linkage was at the fork crown not the axle ! Spooky dook
Posted : 10/07/2013 5:55 pm
I wonder what the fast lads on the 29" rigid race bikes will make of that?
Posted : 10/07/2013 5:58 pm
I'll take the on-one budget version for a bit of comfort on my rigid singlespeed.
Posted : 10/07/2013 6:07 pm
Now it's very possible i'm getting this wrong, but isn't approx 1kg for 60mm of (underdamped/non adjustable) travel really not that impressive? How much mass does the lightest short travel conventional airsprung fork have??
Posted : 10/07/2013 6:09 pm
 LoCo
Interesting, what's the life span on those?
Posted : 10/07/2013 6:13 pm
5 year guarantee offered and 130000 cycles on the test bed from the link
PS how would you service that bad boy ...cynicAl would have you out of business in weeks with his spoon bodgery 😉
Posted : 10/07/2013 6:26 pm
~1500g for some top end 29er Sids. I bet the most common rigid forks on here is the [url= http://www.on-one.co.uk/i/q/FOOOCAR/on_one_carbon_fork ]On-One[/url] style jobbies, which weight almost exactly the same as the above.
A lot of race frames are still built around 80-90mm forks anyway. 20-30mm travel lost, for 1lb weight saving. Looks to be mud proof and have a ton of clearance at the top as well.
Posted : 10/07/2013 6:29 pm
How does it resist the twisting from the disc? Even my old Maverick SC32's used to veer to one side slightly.
Posted : 10/07/2013 6:35 pm
Total rubbish. In reality very few are, the size 15in Specialized have 90mm forks, but almost every other bike is 100mm.
The guy riding it in the pictures looks like he could lose about 20lbs before worrying about losing the weight from his forks.
Posted : 10/07/2013 6:49 pm
Indeed.
I think fork mounted camera footage of it's lateral tracking through ruts would also be interesting.
Posted : 10/07/2013 6:51 pm
I thought they were having a " Lauf"
I'll get my coat 😆
Posted : 10/07/2013 6:56 pm
it doesn't matter if the travel is only 60mm or so as long as the axle to crown is adjusted accordingly in the design so it won't steepen the head angle on frame for 100mm. My issue is the 45mm offset..would feel old skool 29er pretty barge like on a lot of 29er frames that have moved on and designed for longer offsets.
Posted : 10/07/2013 7:00 pm
Slightly dramatic reply there to 10 mm 🙂 My point still stands.
I'm using a 23" 2012 Stumpy HT at the moment which uses 90mm*. Prior to this I used a Scandal which was corrected for 80mm. Cannondale still use 80-90mm on all 29er hardtails? I think Specialized + Cannondale alone would constitute "a lot" on the subject of racey bikes? 🙂
*[url= http://www.specialized.com/us/en/bikes/mountain/sjht/stumpjumperelitecarbon29#specs ]http://www.specialized.com/us/en/bikes/mountain/sjht/stumpjumperelitecarbon29#specs[/url] - this years models, 80mm for smallest, 90mm for the rest.
Posted : 10/07/2013 7:20 pm
Any engineer worth his/her salt would notice a major flaw with this design straight away... 🙄
Posted : 10/07/2013 8:21 pm
hmmm, so if I understand this correctly its a carbon spring, relying on some "inherent" damping in the carbon? ( more likely any damping comes from the resin system the carbon springs are laid up with, if there is any resin?)
I wonder if you took a decent light weight 80mm travel trail fork, took all the damping kit and oil out of it, and replace the steel/titanium spring with a carbon equivalent spring if you would not be far off the same weight?
Posted : 10/07/2013 9:33 pm
Goes to check calendar to make sure it's not April 1st.
It's going to self steer something crazy, there's only the axle trying to keep the left and right sides in sync...
Posted : 10/07/2013 9:47 pm
Its a load of tosh, forget about it.
Posted : 10/07/2013 9:52 pm
..speaking of proper mad stuff from the 90's I thought it reminded me of something:
Posted : 10/07/2013 9:54 pm
That Smokestone looks a bit crazy. Reminds me of those home modified bikes that came up on eBay about six months ago...
Posted : 10/07/2013 10:35 pm
I'd rather have a few grams extra for 30mm more travel and damping and a stiffer fork
Posted : 10/07/2013 10:37 pm
Just read CFH's thread and its lead me here to comment..
I like the engineering angle, well thought out, prefer the knitted jumpers though.
Wouldn't have it on my Niner, sorry.
Posted : 10/07/2013 10:38 pm
Lots of assumptions in here tonight.
Who knows if this is less stiff than a conventional fork as there is no data.
Damping - why would there be no damping? Play tennis with an aluminium racquet and then with a carbonfibre one and tell me they feel the same.
60mm of travel is still better than a rigid fork.
Brake twist - maybe they are designed to resist the braking loads? Again no data to say either way.
I like it. Now build a frame with similar technology for the rear and give me a 60mm travel 1.2 kg full suspension frame.
Posted : 10/07/2013 10:54 pm
undamped frame with no rebound control? pedal-bob-a-rific surely?
Posted : 10/07/2013 10:56 pm
If braking forces cause flexible. It's more likely to make the wheel cant sideways to the right - its well reinforced fore/aft.
I like it. Innovation is good. Could something bonded in between the leaves a la Softride, for damping?
You have to wonder about a single sided version?
Posted : 10/07/2013 11:07 pm
10/10 for missing my earlier comment on damping.
Al - yup, completely feasible that something could be placed between the springs to change the damping but you could also just swap out the springs with ones with a different properties such as different amounts of viscoelastic materials.
Posted : 10/07/2013 11:30 pm
Might see it on Paris-Roubaix
Posted : 10/07/2013 11:39 pm
Seem to have submitted a patent... no pics though
https://www.google.com/patents/WO2013046236A1
Posted : 11/07/2013 12:09 am
Cool idea, for added awesomeness I think it needs some holes drilled in it somewhere and some purple anodising incorporated into the colour scheme...
It's a very clever simple idea. I think the tracking issue is probably lessened by the through axle?
Posted : 11/07/2013 2:25 am
0/10 for assuming that just becasue you typed it, it must be true. I'm sure he read it, just decided it was incorrect. How much damping is there in that carbon? Eff all compared to an actual damper unit. You can see from the video it bobs on small bumps. The tennis racket analogy is incorrect, the carbon racket feels more flexible because it is more flexible. Nothing to do with damping.
Posted : 11/07/2013 5:22 am
A lot of assumption and speculation going on here based on a couple of photos and a video clip.
Perhaps, assuming that this is a commercial venture and not just a design exercise, one will be made available for test. The only way to tell if it works would be to let somebody actually ride it.
Posted : 11/07/2013 7:02 am
The 'spring' bit isn't new, it's just a flexure. Used all over the place (eg F1 suspension) to give friction free movement. Look in any compliant mechanism text book.
Posted : 11/07/2013 8:18 am
How does one adjust spring rate?
Posted : 11/07/2013 8:31 am
You don't, three different stiffness's available.
Posted : 11/07/2013 9:27 am
Thickness (or construction) of the flexure.
Posted : 11/07/2013 9:29 am
Or any old horse cart in a museum.
Posted : 11/07/2013 9:33 am
Hold on - the two sides aren't linked, are they? What's to stop it deflecting left to right besides the axle being clamped in?
I'd have to ride it, to be honest.
Posted : 11/07/2013 9:36 am
The axle being clamped in it.
Its not a massive problem on upside-down forks, like Mavericks, where the two lowers are only joined by the axle. And i guess the flexures are designed to flex vertically and be stiff sideways.
Bonkers. Probably even quite good in a few situations. Ugly. But I love the fact they've got the balls to try something different, regardless of what the armchair (and real) engineers on the forums say.
Posted : 11/07/2013 9:38 am
