[Closed] 142+
[#4906102]
Another standard that seems to have slipped by me- is it correct that this will only fit Specialized frames?
Posted : 25/02/2013 9:13 pm
 Kuco
No a lot of frames now come with this.
Posted : 25/02/2013 9:21 pm
Pretty standard on every 6" travel AM bike these days.
Posted : 25/02/2013 9:23 pm
Really? 142+, not 142. Who else is using it?
Posted : 25/02/2013 9:24 pm
I think the + is a Spesh only thing.
Posted : 25/02/2013 9:25 pm
142x12 or something different?
Posted : 25/02/2013 9:26 pm
142+ is just about the distance between the hub flanges. Everything else is the same and would fit any frame with a 142 rear.
Ok, thanks, but just trying to confirm whether the wheels will or won't fit a normal 142 frame.
Posted : 25/02/2013 9:27 pm
 ndg
I wasn't convinced 142+ wheels wound work with a 142 frame. I think 142 wheels will work with a 142+ frame - but google it, I found the info a few weeks ago.
Posted : 25/02/2013 9:42 pm
Normal 142mm wheels will work with any 142 frame including Specialized 142+. Specialized 142+ wheels won't work in any frame except Specialized 142+ frame. I guess the small sprocket will mush against the frame. Nice work, Specialized.
Posted : 25/02/2013 10:02 pm
cheers Jon, just found that doc on the Specialized site as well. So. looks like the endcap on the drive side is 2mm shorter on the +, so won't fit.
Posted : 25/02/2013 10:07 pm
Seeing as Spesh wheels are utter tosh this should not cause to many issues for people
142+ Spesh frames are just fine with any 142 wheel set
Posted : 25/02/2013 10:16 pm
That's ****ing ridiculous.
Posted : 25/02/2013 10:36 pm
I take it "142+" is to accommodate a bastardised capreo cassette for the works demos and such like?
Posted : 25/02/2013 10:51 pm
well there goes Specialized down the same path as Scott Sh*te, Oh look my proprietary part has broken on a week long holiday, guess I'll need a new bike or go home then...
Posted : 25/02/2013 10:53 pm
Well got a set of 142 + Rovals in the garage never used if you want a spare set? 8)
Posted : 25/02/2013 11:02 pm
so the only difference is the cassette is 2mm further out?
Posted : 25/02/2013 11:37 pm
didn't realise this, my Epic 29er came with a 142+ hub, which fell apart after not very long, replaced under warranty with an Shimano XT 142 hub,
Posted : 25/02/2013 11:59 pm
