XT rear mech - unus...
[Closed] XT rear mech - unusual issue
9 Users
Offline  rascal
Share this post
Mech not springing back so decided to clean the clutch in my XT M8000 mech.
Following a good YouTube vid...only problem is the roller bearing doesn't slide off the pivot bolt like it should....it's solid - almost like they are welded together! Clearly it can't spin on that bolt and do it's job properly as it is. Crap description but any ideas how I can re-separate them? Tried pliers etc and boiling water - nothing giving 🙁
Posted : 25/01/2021 5:28 pm
Offline  StuF
Share this post
I've just had similar, I had to prise the roller bearing off using a screwdriver to lever it off. Then after much soaking in WD-40 and regreasing, I managed to get it going again.
It did take a few tries to get it freed up
Posted : 26/01/2021 8:59 am
Offline  steel4real
Share this post
You will always have problems if you don't do the required maintenance See Page 28
Posted : 26/01/2021 9:09 am
Offline  Davesport
Share this post
You will always have problems if you don’t do the required maintenance See Page 28
Top tip. Never even knew !
Posted : 26/01/2021 9:47 am
Offline  rascal
Share this post
StuF - that was actually my next move so when I saw you reply it gave me hope! The bearing popped off the pin easily - now soaking in GT85 so fingers crossed. Noticed the tiny O ring has perished on the pin though - hopefully not too detrimental.
steel4real - thanks for the link to that manual - very handy.
Posted : 26/01/2021 10:15 am
Remove ads
Offline  StuF
Share this post
Interesting the manual says not to grease the inner rollers - although that's the bit that ceases up. I did grease the inner rollers, slide it onto the pin a bit then twist it a bit then slide it on a bit more and repeat until it was running freely again.
Admittedly I've not ridden it yet since I've fixed it so it might all explode but it looked like it was running much better
Posted : 26/01/2021 10:39 am
Offline  dirkpitt74
Share this post
Thanks for the info - I'll give both of mine a strip down and re-grease.
Posted : 26/01/2021 4:39 pm
Online  scaredypants
Share this post
manual says not to grease the inner rollers – although that’s the bit that ceases up
In my brain, the inner bit should "grip" so that the cage can't rotate without it also rotating and then the outer clutchy mechanism can determine whether that gripped bit is damped in its rotation ??
Posted : 26/01/2021 5:09 pm
Offline  montgomery
Share this post
I do a yearly strip down of my XT mech (two weeks ago, in fact). Keeps it all running nicely.
Posted : 26/01/2021 7:00 pm
Offline  rhayter
Share this post
Shimano specify a particular grease – what's everyone using and what's the Shimano stuff called (the manual only gives the part number)?
Posted : 27/01/2021 10:40 am
Remove ads
Offline  dirkpitt74
Share this post
It's this stuff:
Shimano Grease for Shadow Plus Rear Derailleur - Y04121000
Posted : 27/01/2021 10:44 am
Offline  fadda
Share this post
Interested in this, since my rear mech has never been apart in about 4 years.
How vital is the "correct" grease, and will my bike explode if I just use normal stuff...?
Posted : 27/01/2021 11:38 am
Offline  rascal
Share this post
Got the bearing off the pin - levered off with screwdriver in the end.
Few other broken/perished bits so new bits ordered for £15 delivered.
Cheapest new mech was £70 so quite a bit cheaper unless I **** it up!
Posted : 27/01/2021 1:29 pm
Offline  montgomery
Share this post
How vital is the “correct” grease
It isn't. I just use the same marine grease I use for everything else. No issues between yearly stripdowns, a contrast to the problems I had with the clutch binding badly six months after I first got it.
Posted : 27/01/2021 4:26 pm
