Wheel dishing tool?
[Closed] Wheel dishing tool?
14 Users
Offline  joebristol
Offline  davy-g
Share this post
I made one out of scrap wood and an old broken spoke, cost was FREE...
Posted : 07/09/2018 5:45 pm
Offline  joebristol
Share this post
Nice - assuming you are capable of vaguely accurate woodwork. Not my strongest skill. Would your tool manage for 26 / 27.5 29” wheels though? I assume you use the spoke to measure the distance from the rim to the end of the hub?
Posted : 07/09/2018 6:02 pm
Offline  davy-g
Share this post
I followed the instructions for the dishing tool from Roger Musson's great book on wheel building...all my bikes are 26" wheels, but I would imagine that it would be adequate for 27.5" and 29" as the tool has a fairly wide footprint...the measurement spoke can be moved forward or back to measure from the appropriate point on the hub.
Posted : 07/09/2018 6:06 pm
Offline  andyl
Share this post
Got the X-tools one from wiggle and it's fine. The middle bit needs a suitable hub bit to sit over or butt up to but once on it's fine and nice and stable.
Has anyone else noticed that the brown road sign symbol for a ballroom looks like a dishing tool?
Posted : 07/09/2018 6:10 pm
Offline  joebristol
Share this post
I didn’t know there was a brown road sign for a ballroom - seems like quite a niche road sign requirement?
Posted : 07/09/2018 6:21 pm
Offline  nixie
Share this post
The wooden one above can also be made from cardboard.
Posted : 07/09/2018 6:27 pm
Offline  Rubber_Buccaneer
Share this post
I have the X-Tools one (it was called Lifeline when I bought it) and it is good. For that price I couldn't be bothered to make one
Posted : 07/09/2018 6:36 pm
Offline  otsdr
Share this post
Assuming you only need to get the rim centered, there is no need to put the wheel on the bike, you can just flip it around in the truing stand.
If you really need an offset wheel (i.e. Cannondale Ai), then a dishing gauge is a must-have.
Posted : 07/09/2018 6:40 pm
Offline  spaniardclimber
Share this post
I use two empty jam pots on a table to support the rim on opposite sides, then I pile coins at the axle, flip the wheel and voila, free, and doesn't take space or time/skills to build.
I've built 5 wheels so far with this method.
Posted : 07/09/2018 10:00 pm
Online  scotroutes
Share this post
I have a dishing gauge that came free with my Minoura wheel truing stand but I prefer to just flip the wheel in the stand.
Posted : 07/09/2018 10:05 pm
Offline  mick_r
Share this post
Same here - just flip the wheel in stand.
Posted : 07/09/2018 10:12 pm
Offline  joebristol
Share this post
The dish tool arrived yesterday - should do the job ok. Feels solid but light and nothing really to go wrong. Bit expensive for what it is but a nice to have.
Posted : 11/09/2018 7:49 am
Offline  zbonty
Share this post
I made one a la Roger Musson's design but will try stacking coins next time.
Next time will be quite soon as my front wheel on the commuter was vandalised whilst i had a couple of pints- tossers stole the QR then stamped on wheel as they could'nt remove it pressumably (unhooking the V-brake noodle would have helped). Amazingly the front axle was sheered 🙁
Posted : 11/09/2018 8:11 am
Offline  peaslaker
Share this post
Flipping the wheel in the stand gives an indication of double the off centre measurement. A wheel dishing tool indicates 4 times the off centre measurement.
I just take the wheel off the stand and place it on a flat bit of kitchen work top. Place the rim with the valve hole against the wall side of the worktop and the rim touched against the surface. Stack up anything to fill the gap from surface to rim at the near side. Flip wheel and the difference is four times the off centre measurement just like a dishing gauge.
Posted : 11/09/2018 8:18 am
Offline  johnners
Share this post
Say what now?
Posted : 11/09/2018 8:29 am
Offline  TrentSteel
Share this post
+1 for cardboard, last one was a 2 minute job with scissors and they are just as accurate
Posted : 11/09/2018 9:26 am
Offline  cynic-al
Share this post
What druid and mick said.
Posted : 11/09/2018 10:14 am
Offline  peaslaker
Share this post
Say what now?
You're determining dish by reversing the wheel in a jig.  You don't know where the absolute centreline is.  One way round you wind in a pointer to touch the rim and then you reverse the wheel and it leaves a gap to the pointer position.  The gap you have measured is double the adjustment you need to make.
If you use a dishing tool, when you adjust it to touch on side A of the wheel, you adjust the centre position so that the tool touches at two diametrically opposed points.  When you flip it over and place the tool on side B, the same thing is happening.  The tool can have a gap of double the adjustment you need to make *at both diametrically opposed points*.... but what you do is you press one of the ends of the tool onto the rim and the gap at the other end opens up to be "double the double offset" - four times the adjustment you need to make.
It is an analogue multiplication that means you're not diddling around with dial test gauges - you're looking at a big old gap and there's very little ambiguity.
Posted : 11/09/2018 10:01 pm
Offline  joebristol
Share this post
I won’t claim to understand the above, but I like my new dish tool. Had the wheel into the right place within 10 mins flat.
Posted : 11/09/2018 10:23 pm
