I have SKS AL Edge mudguards. I’ve generally been pleased with them. However, I have recently been using slightly bigger tyres, and when I put the mudguards on for winter the rear has started to make a banging noise when I drop off a kerb or hit a bumpy patch.
After much investigation I think I’ve discovered what’s happening: The mudguards have three fixing points (I hope the following makes sense) – near the bottom bracket, the bridge, and a pair of struts. The problem is that the distance between the bridge and the struts is too large, so the mudguard can hit the tyre at th top after a bump as it flexes.
My proposed solution is to saw a bit – maybe 12cm or so – of the mudguard off at the front end, drill a new hole and move the whole mudguard forward (again, I hope this make sense. If you were looking at the bike from the side with the front to the left the mudguard would move round a few degrees anti-clockwise).
This would shorten the mudguard and bring the struts closer to the bridge, hopefully providing more stability, less wobble, and stop the banging.
I don’t use this bike for group riding, only for a lonely commute, so I don’t need to worry about splashing anyone behind me, and the length would still be enough to protect my back from the wet.
So, will this work? Or will I have a less effective but equally noisy fender?
Thanks for any suggestions/advice/potential problems.
