Home Forums Chat Forum Waterproofing a roof from the inside?
Viewing 10 posts - 1 through 10 (of 10 total)
  • Waterproofing a roof from the inside?
  • jamesgarbett
    I’ve inherited a garage which is great except it’s got a leaky corrugated steel roof
    For various reasons I’m not allowed to do any repairs on the roof itself
    What would be the best thing for me to put on the inside of the roof to at least stop some of the water getting thru to the floor? I’m thinking some kind of heavy duty plastic sheeting tacked from corner to corner
    Greybeard
    Are you allowed to stick patches on the underneath? Flashband would work.
    Matt24k
    You need to stop the water getting inside the garage unless you have some sort of internal drainage system as any repair method that is positioned below the existing structure will just collect water.
    Assuming that the corrugated steel roof has holes in it, I would attempt to patch those from the inside with sections of sheet, mastic and maybe fibre glass patches etc.
    jamesgarbett
    Yes I can do anything on the inside – needs to be cheap/temporary as the whole set of garages will be re-roofed in 2021
    joshvegas
    Poke umbrella through hole.
    Deploy umbrella.
    trail_rat
    if its localised and you know where its coming in.
    flash band + flashband primer
    if its all over and you can leave the garage open to the air for a few days – and its just for storage rather than actually for say turbo training.
    Fixrcryl it.
    Holyzeus
    Flexacryl or Acropol will seal 10mm gaps
    Good stuff
    kevs
    I used to work at a train depot with a leaky roof above an expensive electrical machine, the repair was clear polythene sheet spread out as an “under roof” with a hose fitting at the low point with a hose going to the drain nearby. It was awful but it worked.
    There is a picture on “on the tools” I think
    singlespeedstu
    jam-bo
    Positive pressure. Blow it out…
The topic ‘Waterproofing a roof from the inside?’ is closed to new replies.
