Which would also mean with a wheel on trainer your reactions could throw it completely as it hasn’t really anyway of knowing you stopped applying power when it says so
It doesn’t need to.
You spin it up to “at least ……. mph”, lets say ….+1. Stop pedaling, and a few seconds later it’s exactly …..mph, it then times how long it takes to drop to some other figure*. It doesn’t need to react to you stopping, it just starts the clock when it reaches a certain speed on the way down.
I was looking at getting a solid tyre for the turbo so maybe this is enough reason to do that.
Turbo tyres aren’t solid, they’re just designed to work better once warm. Running old road tyres leaves a black stripe of rubber dust up the carpet. The bright orange conti trainer tyre still sheds some crap but nowhere near as much.
*I’d assume it’s not actually zero, you could get a much more accurate measurement by calculating the differential of the speed, which would give you the drag force at any speed.
