The easiest brakes I’ve ever installed .
Levers come plugged separately from calipers
Hoses are bunged so great for routing internally first .
I just then cut the hoses to length
Fitted new insert
Connected
Then just bled the lever
Done that on both sets and there rock solid
No deviation of lever feel
The trp pads are organic made by galfer equivalent to there green compound so bed it quickly and are silent
I would personally run them with the trp rotors which are 2.3mm thick
They were on offer at merlin for a tenner each but are out of stock
But if on a budget you can pick up tektro tutors 2.3mm thick which are made by trp
