Hi all, glad your frames are turning up on time, appologies for any of you still waiting.
Just to clear up a couple of headset issues…
The only headset we know definately fits the FTM Carbon (as in we have fitted and ridden it) is an FSA CF-40 No. 42 ACB, be careful here though as apparently there is a non-ACB version that won’t fit. We’re trying to get stock direct from FSA ASAP and hope to have them on the site within a week. If you fancy seeking out your alternative an headset you’ll need make sure it’s integrated 42mm top / integrated 52.1mm bottom, (S.H.I.S. Code: IS42 | IS52).
As for the Rockstar, our Smoothie Mixer headset will work, as it will on the Aluminium FTM, but not the carbon. Don’t forget the aditional crown race if you wan’t to run it with a tapered steerer though.
Hope this helps.
