kelvin
In the mullet position, it uses a special post mount brake adapter to use a 180mm disc… that adaptor comes with the frame. I checked this with Cy yesterday.
In the full 29er position, standard post mount brake adapters can be used for 180 or 200 (or 203) discs.
Cool… although I liked the idea that they had somehow just lined it all up with the old fashioned IS mount that’s pictured
chiefgrooveguruFull Member
Is Transmission compatible with the ethos of a burly steel hardtail?
Well, there are mechanical versions on the way, it seems – tbh, I’d have it on all the bikes if I could, just to avoid the constant hanger tweaking that’s a feature of 12 speed
