I actually also bought a pair for my Sonder Cortex. You can find them brand new for around £135 on ebay from a German seller. I also took a total punt on them as there is very little information regarding them online anywhere, but I decided that £140 for a brand new fork with warranty was less of a risk than more than £200 for a second hand fork. They’ve been specced on a few Giant ebikes too.
I have been genuinely impressed with the fork. The build quality is excellent (certainly matches that of FOX/RS forks), the 15mm skewer is a really cool design, the integrated mudguard is excellent also. I’ve ridden mine loads since I’ve had it and it’s really quite acceptable. Mine has the medium coil and I’m 80kg. It’s perhaps a touch too hard for my tastes but I used 130mm of the 140mm travel at BPW last week so they’re not a mile off in fairness.
I moved over from an old skool Coil Pike and I’d say that they are comparable. You only have rebound damping to play with as the lockout is all or nothing. Harder and softer springs are available (although Suntour suggest the soft is for sub 70kg and the hard is for over 90kg). From what I’ve read, you can upgrade the damper assembly from the more expensive forks too for around £120 when I looked before.
So, overall, for the price of sub £150 it’s genuinely excellent and I’d totally recommend it. It’s not got the adjustment and performance of a top spec fork but it probably shouldn’t be directly compared to them as the price difference is too great. I bought it thinking that if it was terrible i’d just upgrade sooner rather than later but I’ve not no plans to replace it just yet. It performs a lot better than I do!
