I had a Cube 120 AMS that this happened too, twice. Mate had a Stereo that it also happened too.
From what I can see the problem lies with the bolts just not being up to the job, they just aren’t big enough. On my AMS it was just a small bolt each side that screwed into the frame.
I did fix mine in the end – Did a bit of measuring & found that the main pivot bolt set up on my old Giant NRS that goes right through the frame was just the right length to do so on the Cube as well. Couple of pilot holes later & then lastly with the correct size drill bit I put a hole right through the frame where the pivot bolts go. There was plenty of metal there so it’s plenty strong enough. Had no more problems with it after that, far better set up & a lot stronger.
