I find 99% of the pad squeal is poor caliper alignment. No different to old school rim brakes squealing if the pads didnt toe properly.
If i drag the brake and they glaze they’ll squeal but all other times its the alignment.
If you brake and can see the disc move – badly aligned. If you can see one pad hit first – badly aligned. If one end of the pad is closer than the other – badly aligned. All of which cause squeal or noise to some extent.
Everyone says calipers push evenly and self centre. Both to a point. But in reality they dont and why 4 pots are more hassle than 2 pots to set up.
If you have rattle when the brakes are applied then thats a serious problem as the pressure of piston to pad to disc should stop the rattle.
Just get non-finned to stop normal movement rattle. Shed loads cheaper than finned too.
