Is there anyone in the Exeter Devon or surrounding area that does their own spannering on their reverbs?
As the old saying goes, the devil makes work for idle hands, I have an old spare reverb that was sitting around and in a moment of boredom I decided to investigate how far I could work on it without the proper tools and vices and soft jaw clamps etc.
If youve seen any of my other posts you would know I’m a hacks and bodges type of moron.
I don’t need the reverb it’s just an emergency spare should something go wrong with my main dropper and I need something to use while the proper one is being replaced or worked on.
I was seeing how far I could take it apart but there was stil some air pressure left in it so the poppet blew off and I lost some of the fluid inside and also apparently the IFP would have shifted inside.
I could send it to RSF in Plymouth for a service and rebuild but £85 seems a bit of an unnecessary spend on something that is just going to sit in a box of spare parts and probably never get used. It WAS working fine and doesn’t need a service or any seals replacing etc.
Is there someone who would be willing to undo the seal heads and resit the IFP at right height and retop up the fluid to required level for a suitable reward? Or failing that rent me suitable tools to get the job done myself.
I just don’t have the necessary tools to clamp the shafts and body etc to undo the seal heads
Thanks
