Home Forums Bike Forum Replacement for NX Eagle derailleur
Viewing 15 posts - 1 through 15 (of 15 total)
  • Replacement for NX Eagle derailleur
  • pavlos
    Hi all
    First post here, so nice to meet everyone.
    I have a damaged NX Eagle derailleur that needs replacing. Turns out there are stock issues everywhere until October. So I wonder if it’s an issue downgrading to an SX eagle derailleur, or whether it’s worth upgrading to GX. Considering cost, obviously, and I understand the GX would require a new XD driver if I were to change the cassette at the same time.
    So is it pointless downgrading? I’m not doing more than 40k a week. If I upgraded could I stick with the 11-50t cassette and NX shifter? Appreciate that’ll probably make the derailleur less functional than it should be.
    johnnystorm
    I’ve heard SX can be a bit flimsy so I’d be tempted to go for GX. You won’t need a new driver or cassette unless yours are really worn out or you want to take advantage of the 10-5p cassette rather than your current 11-50.
    It might not shift as nicely as a full GX set up but it won’t be worse than an NX, certainly not a worm out NX!
    tomhoward
    If you get a GX mech, you don’t have to use a GX cassette, any eagle cassette (and in reality, any 12speed cassette) will be fine.
    All eagle stuff works together.
    Murray
    And if you can find a Shimano 12 speed mech it will work as well
    earl_brutus
    When I cooked my x01 eagle rear mech I replaced it with a GX and literally cannot tell any difference between the two. Saved £80.
    joebristol
    Just get a Gx eagle one – it’ll be more durable and fine with what you’ve got.
    jonba
    My Scandal came with a GX mech and lower end hyperglide cassette. Shifting is good so far.
    timbog160
    GX definitely
    Kuco
    I got a GX rear mech last week through Mantel and it’s the latest model that can use 52t cassette but I’m running it on a 50t NX cassette fine.
    susepic
    Or, as Murray mentions, run a shimano mech. Had the same issue 3 months ago. I couldn’t find a NX mech, so bought an SLX one. It’s running with no probs (probably better than the NX) using the NX shifter on the 50-11 NX cassette.
    pavlos
    Thanks all.
    Well looks like stock issues on the GX now too, so may try the SLX. Take it that’s the M7100?
    luket
    Shimano here, and I found a Deore in stock the other week for £62 to replace my XT. A friend had just replaced an SX under warranty. That’s more money than Deore, or even SLX, if buying. The Deore is in my view superior for the clutch that works and is adjustable. I did need to adjust it at the outset though. 2 other friends replaced better SRAM 12 speed mechs with shimano recently without issue and are happy with them. All this across DEORE-SLX-XT, between which for your (and my) purposes it’s splitting hairs in my view.
    But stock is king in 2021. You’ll be dependent on what you can find…
    susepic
    M7100 is the 12 speed. Still showing in stock at Merlin.
    Clutch seems to work fine, have had zero issues with it since going on. Was adjusting my NX every other ride.
    https://www.merlincycles.com/shimano-slx-m7100-rear-derailleur-12-speed-179601.html
    tabletop2
    I put a deore one on when my NX broke. Way more sturdy as well as being cheaper. Everything else still sram NX and works fine together
    pavlos
    Nice one. Thanks all
The topic ‘Replacement for NX Eagle derailleur’ is closed to new replies.
