Previous experience has taught me that it doesn't only mean that...
Previous experience has taught me that it doesn’t only mean that…
Quoting fixed?
Quoting fixed
Quoting fixed
<div class="st-topic-reply ">
<div class="loop-item-2 user-id-16367 bbp-parent-forum-180317 bbp-parent-topic-10172749 bbp-reply-position-3 odd post-10172783 reply type-reply status-publish hentry">
<div class="bbp-reply-author">wrightyson
<div class="bbp-author-role">
<div class="">Member</div>
</div>
</div>
<div class="bbp-reply-content">Quoting fixed
<span class="bbp-reply-post-date">Posted 7 minutes ago</span><span class="bbp-admin-links">REPLY | REPORT</span></div>
</div>
</div>
<div id="post-10172798" class="bbp-reply-header">
<div class="bbp-meta"></div>
</div>
<div class="loop-item-3 user-id-7695 bbp-parent-forum-180317 bbp-parent-topic-10172749 bbp-reply-position-4 even post-10172798 reply type-reply status-publish hentry">
<div class="bbp-reply-author">angeldust
<div class="">Subscriber</div>
</div>
</div>
</div>
</div>
</div>
Apparently not...
Plus it can only mean something is coming
@mechanicaldope when you get all that guff, are you just quoting the words you wish to reply to, or trying to copy the whole post?
name member
content
posted 4 minute ago
and all the formatting etc?
Quoting fixed
seems fine to me
<div class="bbp-reply-author">tomhoward
</div>
</div>
name member
content
posted 4 minute ago
Quoting fixed
seems fine to me
</div>
name member
content
posted 4 minute ago
again, seems ok to me.
So working for some and not others is working?
<div class="bbp-reply-author">mikewsmith
</div>
</div>
<div class="bbp-reply-content">So working for some and not others is working?
</div>
clearly not
Quoting works fine for the body but if you copy in all the header etc and dump it in you get all the formatting popping out
Don't copy in the username.
so loss of a function is progress? Are the IT bods outsorced to SFRS they have single hardly ****ed up the whole IT system.
Don’t copy in the username.
Who said that?
Yeah what a huge loss of function function. 🙄
Is that until somebody fixes it?
If you want yes but it's something I've never done.
<div class="bbp-reply-author">Drac
</div>
</div>
ahhh!
</div>
Reminds me of those Tesco self-service machines. "Help is coming." Strikes fear into all.
To be fair, it was only when you included the name previously. Just thought that may have been fixed .
What happens if something is in <span style="text-decoration: underline;">italics and underlined? </span>
Edit- Yup
Reminds me of those Tesco self-service machines. “Help is coming.” Strikes fear into all.
Back in my early IT support days, I once walked past a desk where a woman was sat with her arms folded, she spotted me and went, "well, it's about bloody time!"
I said "er, what do you mean?"
She replied, "well, I pressed F1 for help ages ago!"
<span style="text-decoration: underline;">Don’t copy in the username</span>
then it gets lost in a thread who said what.
your defence of all that is stw is admirable
@notlocal double award winning tho
She replied, “well, I pressed F1 for help ages ago!”
....at which point, you should have leaned over her keyboard, pressed Escape and then buggered off.
If it appears three times quoted in the same post you know what will happen....
Ah, **** it.
….at which point, you should have leaned over her keyboard, pressed Escape and then buggered off.
PMSL
Who said that?
I've no idea, this forum functions using written words. 😉
Ha, I don’t even get the quote box.
I have to manually type in [ quote ] etc
piemonster
<div>Member</div>
</div>
<!-- .bbp-reply-author -->
</div>
It’s an alternative not a defence.
Plus it can only mean something good is coming’
Its right, I’m getting a long over due hair cut tomorrow.
I look like Bono from the late 80’s.
Well that does seem to be the default setting in IT. Certainly where I work (and I work in IT!), progress seems to equate to prettier front end and less functionality.
WTF is actually wrong with this broken forum?
Other forums seem to work with quotes, a working search function and no random load of coding if you copy and paste stuff. Im surprised the crowd hasnt dispersed and started to hang out somewhere else....
cloudnine
</div>
</div>
<div class="bbp-reply-content">WTF is actually wrong with this broken forum?
</div>
Despite protestations that the previous version was riddled with custom bits of code that made it unserviceable, we're now using a standard piece of forum software that has been custom coded to make it shit.
I've been getting 502 errors today.
Quoting seems to work if you just copy and paste text into a reply and then wrap it in quote tags.
<div class="bbp-reply-author">mattyfez
</div>
</div>
I’ve been getting 502 errors today.
</div>
Stop whining.
Despite protestations that the previous version was riddled with custom bits of code that made it unserviceable, we’re now using a standard piece of forum software that has been custom coded to make it shit.
Yes, but that breaking news about Hannah's distaste for cows would have been impossible under the old system.
I've been seeing the occasional 5xx error for a good while too, a refresh usually sorts it out though. The not seeing edits immediately after making them - is that a browser side cache thing?
Is that copied from here or another site?
no copy / paste. Simply typing the text, highlighting the words and use the formatting buttons
Hmmm! Which OS and browser <span style="text-decoration: underline;">version?</span>
Ah! Right got it.
Seems if you type the text, highlight it and press the format it breaks.
However if you press the format button then type the text it doesn't.
I think when I originally posted it was iOS
Not sure what difference it makes on <span style="text-decoration: underline;">OSX / Safari</span>
Edit - But I do now
Yeah I use iOS it only works if I click the bbcode button before typing. 😕
Essentially though, OS/Browser/Mobile/Desktop nuances aside, this is still the sort of thing that was sorted what ~15 years ago(?) on just about any other forum...
And it's not just "teething troubles" we're several months into the "improvements" and you still can't just bash out a simple post, paste in a link, image or apply Blockquote without triggering a slew of redundant markup gibberish... If the user's can unintentionally make a bollox of posting it's just not fit for purpose.
It's crap, and those of us with a 'P' sort of think of ourselves as the "Customers" (rightly or wrongly), so when do they sack the dev and start again?
What a miserable bunch of moaning gits.
I’ve been seeing the occasional 5xx error for a good while too, a refresh usually sorts it out though. The not seeing edits immediately after making them – is that a browser side cache thing?
I think it goes back to the original post, if you delete the last /#post-10174255 bit from the web address it seems to fix it?
Yes, but that breaking news about Hannah’s distaste for cows would have been impossible under the old system.
Did that thread get edited?
cornholio98
Member
Does it work if you paste as plain text rather than just pasting?
EDIT: Yes, it seems to. Why don't people just do this?
Pasting links and images is easy.
Copy, paste. Done.
That was second choice title for my new mag.
EDIT: Yes, it seems to. Why don’t people just do this?
Because it's not needed anywhere else on the internet, it's there as an option but just not normal.
Because it’s not needed anywhere else on the internet, it’s there as an option but just not normal
Is the correct answer. I frequent a dozen forums and have more than 50,000 posts on one in particular. None have the quote issues or the creative word changing of text that this place has.
No breaking news today then?
I'm getting great ads for a "singles game where you always win" and "5 ways to date" or something. For that reason I'm happy with my free forum membership. Maybe it's the fewer ads that's making it so bad for those with P's?
Granted, but the forum is still wonky months after it was supposedly "fixed" and there's only so much blaming the users you can get away with before they start noticing that most of the rest of the interweb works while STW still doesn't.
there’s only so much blaming the users you can get away with
Yeah as that's exactly what has happened.
What about the logging out issues ?
3 times today, assume it’s some sort of remediation work.
Thankfully it’s not as painful to log back in again, unless you don’t realise you’ve been booted out and about to reply only to see the “you’re an idiot, log in before we allow such missives from people like you”
Not sure Bikebouy funnily enough I got logged out earlier too.
Do you want the short answer or the long one?
STW hasn't been able to replicate the issue. It's something client-side which is causing it, whether that's your web browser or your workflow or what I'm not sure. That is to say, it's probably a forum glitch (and I have my suspicions as to exactly where it is) but the fact it only affects some people means there's something different about the way you're using the site compared to those who aren't affected.
Holy shit you've just blamed the user. Do you realise what you have done?
Nah, I’m cool.
I’ve long since stopped whinging about it, in the main because you are aware of it and now if you do get logged out there are (what seems seamless) ways of logging back in and it’s quick and pretty much like instant.
All Good here.
I would actually really like to get to the bottom of it definitively. It's been a bug-bear for years.
Holy shit you’ve just blamed the user. Do you realise what you have done?
Something that’s happened frequently but usually gets dismissed with a slightly patronising reply?
scotroutes wrote
<span style="font-size: 0.8rem;">Despite protestations that the previous version was riddled with custom bits of code that made it unserviceable, we’re now using a standard piece of forum software that has been custom coded to make it shit.</span>
Ha the singletrack google extension seems to be working now
I took aracers changes and then applied some of my own to make things work with the new site (it's a bit of a pain to deal with the new reply box) :). I'm planning on making it so that it strips excess html tags too and a few other temporary fixes.
I know things you can only dream of.....🙂
Cost? Biscuits.
