As far as i am aware it has nothing to do with the stanchions, the creak is coming from where the steerer tube is bonded into the crown.
Its normally creaky stanchions I fix. (though both can creak)
Both the steerer tube and the stanchions are a press fit, you can press them out, clean and refit with a loctite retaining compound. If they are under warranty then new CSU.
All the OEM ones I have stripped appear to have been assembled dry, no residue like you see on bearings installed with loctite from the factory.
Riding with the top caps slack can exacerbate the issue. The tops caps screw into the stanchions, clamping the crown. Steerer tube is pressed in from below, it has a flange which stops against the crown.
