Flippin-eck! From the Demon Core wiki page (linked from the Slotin page)
The experimenter needed to maintain a slight separation between the reflector halves in order to stay below criticality. The standard protocol was to use shims between the halves, as allowing them to close completely could result in the instantaneous formation of a critical mass and a lethal power excursion.
Under Slotin’s own unapproved protocol, the shims were not used and the only thing preventing the closure was the blade of a standard flat-tipped screwdriver manipulated in Slotin’s other hand. Slotin, who was given to bravado, became the local expert, performing the test on almost a dozen occasions, often in his trademark blue jeans and cowboy boots, in front of a roomful of observers. Enrico Fermi reportedly told Slotin and others they would be “dead within a year” if they continued performing the test in that manner.[12] Scientists referred to this flirting with the possibility of a nuclear chain reaction as “tickling the dragon’s tail”, based on a remark by physicist Richard Feynman, who compared the experiments to “tickling the tail of a sleeping dragon”.[13][14]
On the day of the accident, Slotin’s screwdriver slipped outward a fraction of an inch while he was lowering the top reflector, allowing the reflector to fall into place around the core. Instantly, there was a flash of blue light and a wave of heat across Slotin’s skin; the core had become supercritical, releasing an intense burst of neutron radiation estimated to have lasted about a half second.[6] Slotin quickly twisted his wrist, flipping the top shell to the floor. The heating of the core and shells stopped the criticality within seconds of its initiation,[15] while Slotin’s reaction prevented a recurrence and ended the accident. The position of Slotin’s body over the apparatus also shielded the others from much of the neutron radiation, but he received a lethal dose of 1,000 rad (10 Gy) neutron and 114 rad (1.14 Gy) gamma radiation in under a second and died nine days later from acute radiation poisoning.
