Home Forums Bike Forum Mixing different Wt suspension oils to create a new Wt oil.
Viewing 5 posts - 1 through 5 (of 5 total)
  • Mixing different Wt suspension oils to create a new Wt oil.
  • qwerty
    So, i need approx 135ml of 5 Wt oil for the damper side of my Revelations.
    I have a 1l of 10Wt Fox green suspension fluid & some Rockshox Reverb oil which i believe is 2.5Wt.
    So what ratio do i need to create 5Wt oil?*
    Is it all good to mix Fox & Rockshox oil to create Rockfox?
    *i’ve just finished nights & my brain don’t work.
    Ta
    qwerty
    OoooooooO…. Google foo has shown me this:
    http://www.widman.biz/English/Calculators/Mixtures.html
    Is cSt the same as Wt?
    If so, 46.5% 10Wt & 53.5% 2.5Wt = 5Wt… yes?
    benpinnick
    Yeah sort of, the problem is that your 2.5 and 10 will likely be different to the 2.5 and 10 equivalent of the 5 you need. One companies 5W is totally different to anothers… This is not to say don’t do it, just that don’t be surprised if you end up over / under damped. Luckily with the Moco damper you could just suck out a few CC of oil, add back in the right amount of lighter/heavier depending which way you’d end up and try again.
    qwerty
    Cool, thanks Ben. I’ve got those oils laying around, so i’ll give it a go & see how i fare.
    molgrips
    I’d get the 2.5 with a splash of 10 and then turn up the damping more.  There’s usually much more range of adjustment in forks than the difference between weights IME.
The topic ‘Mixing different Wt suspension oils to create a new Wt oil.’ is closed to new replies.
