I’d suggest they can’t be oversized if you plan on being under it at any point given your reputation. But I’ve seen weightlifters lifting massive weights on (admittedly bending) steel bars of about 1″ diameter, so I assume you’d be able to find something strong enough.
Would I-beam joists, designed for holding house sized weights up not be an option?
I have no qualifying knowledge, but a 1.5t car, front loaded due to the engine, maybe the 4 points would be (pure guess) 500kg each at the front and 250kg each at the rear? 600/600/150/150? You then have a turning moment pivoting around the front of the floor x 500mm, how far to the rear jacking points? Any chance that the whole thing could pivot over the front of the floor, if you were to load or unload by eg: torquing on bolts….if so I’d want the rails fixed down onto the floor, not just sat on it.
