Ok thanks.
My phone is on silent 99% of the time. Mainly because I can’t be bothered switching it on and off at work.
Just checked and if the phone is on silent the do not disturb function doesn’t work.
The only way I can allow phone calls is to allow Emergency by pass on the numbers, so then my parents could ring me in an important meeting during the day.
Doesn’t look an easy solution apart from me starting to remember to flick silent mode on and off… unless you can set a rule based on location (turn do not disturb on at work etc?)
Edit – just noted you can use DND by location, although it doesn’t state the location size. Where I work it’s prob 500m sq site!
