Longer offsets and slacker HTAs for 29ers were Jeff Jones’s thing early on, a few years later the Fargo V1 and Gryphon used the same HTA and offset combo. Then the Jones Plus went further with a 75mm offset and 67 HTA, the Stooges go a bit further with that idea again.
Interestingly for me as a bike nerd early Jones bikes were very short wheelbase (~650mm FC) and though they have a unique mix of agility and stability there’s no escaping the way the shorter trail (~75mm) front end gets pinballed in the rough. The Jones Plus less so as it’s much longer wheelbase for a similar rider position yet the trail increase is only about 10% – that suggests FC and wheelbase do add stability alongside the change in grip/rider position overall vs the front axle. But the Jones Plus is a lot longer, a big difference compared to the older 29er.
imo the added FC that you get from increasing offset 7-17mm here won’t counteract the reduction in trail. The FC difference is ‘a tweak’ but the trail difference is ‘a change’, if that makes sense. You’ll always have a light steering lower trail MTB anyway* so it may work ok, but if the bike feels twitchy now the new fork (I expect) will make that aspect somewhere between worse and unbearable.
Edit, with the same tyre it’s only about 8% less trail than the Jones 29er so all’s not quite as it looks, but the weight distribution is polar opposite.
