Wa gwan.
I’ve got this dust extractor see. Lately though, it just keeps blowing fuses on start-up. Not always, but often. 3-4 a day depending on wood whittling rates.
Untitled by blackteaonesugar[/url], on Flickr
It’s a single phase 240v thing and it’s plugged into an extension that you can see on the wall.
The wiring quality in the workshop I rent is akin to what I’ve seen in the streets of Bolivia but, I’m not sure that’s the issue as it only blows at its own plug, not the fuse board, plus that drill that’s plugged in there is always fine.
It was fine for several weeks, and it’s just started doing it.
I’ve checked everything my limited electrical knowledge is comfortable with, so no obvious loose wires in the plug, the switch, or the start-up capacitor to the motor etc.
I’ve given the machine itself a good clean out to rule out mechanical start up strain. The fan spins lovely.
Help me oh stw. What should I check? How should I check it? (I’ve got a multimeter) what could be causing it?
