I’ve dried the next burn’s wood in the oven after a pizza session before. Need to remember not to close the door to the oven till the temperature has dropped a lot or the wood won’t be there when.you come.back 😆 (rooky mistake).
Haha…i did think about that possibility when i put some inside last night. Tahnksfully is was still there this morning!
Why not just keep a stash inside. A week indoors will dry it out that extra bit.
A while back I found a load of Longhorn Beetles in the living room that had emerged form the wood in the log basket. That kind of put me off keeping lots of wood in the house if it can be avoided.
If your greenhouse air is moist….what’s blowing it over the logs hoping to achieve ?
I was thinking i could put the fan near the louvre vent to help pull in dryer cooler air form outside to blow through the wood.
Kiln dried is marketing for quickly processed wood -saves them having to store it in well ventilated dry areas for long periods
Agreed. The guy i bought the kiln dried oak off supplies a few local pizza restaurants. It is oak offcuts from his saw mill. He dries them (quickly) in a poly tunnel which is open both ends. He reckons he can get them down to ~10% in a matter of a few weeks. I”m essentially trying to replicate what he does on a tiny scale.
