Home Forums Bike Forum Fox Float clunk on rebound?
Viewing 6 posts - 1 through 6 (of 6 total)
  • Fox Float clunk on rebound?
  • Rosss
    In the last two rides my Fox Float rl’s have developed a clunky knock when rebounding. They don’t feel smooth at all. I’ve had them a year now and havent been serviced however have been looked after and only used every other week if that (Weekend warrior ATM). Can any one shed any light on the situation.
    Russell96
    Is the rebound full on?
    LoCo
    Is it at the point of direction change I.E from compression to rebound?
    It’s likely to be a sticky shim, probably due to surface finish on a piston.
    These get re-finished as part of a full service
    Rosss
    Yeah, to me it feels sticky so you could well be right! Thanks for the info guys i’ll look into services.
    LoCo
    Yep that’s quite common, a sticky shim that ‘holds’ for second and then releases leading to the clunk, as I said we sort those as part of the service 😀
    Rosss
    I will hopefully be in touch in a few days then as it’s doing my head in. Thanks for the help!
The topic ‘Fox Float clunk on rebound?’ is closed to new replies.
