Here you go: https://nottenergy.com/resources/energy-cost-comparison/ – the column to compare is pence per kwh after boiler efficiency
The bottom line is that direct electric heating is *very* expensive.
You’re basically asking us, with no further context, if you should pay to install a system that will cost 39p/kw/h rather than 13p/kw/h to heat your flat. If there’s context missing which makes this sensible, maybe. Otherwise, no.
You indicate you’ve decided to go for it. Honestly, that’s quite likely a very costly mistake.
(@poolman: the maths is essentially the same if you “retain” the heat or use it straight away fwiw)
