Old house has no dpm/damp course
Wall is mid terrace between to houses
The floor below the stairs is basically just dirt right down at the end under the first step
There was signs of damp above the stairs when I moved in which I hacked off and had replastered, with no actual fix for the damp (bare with me I was new to this)
The under-stairs entrance door has been off all year, and so has the adjacent kitchen door one so loads of lovely airflow, last week I put doors back on both the kitchen and under-stairs – et voila, big patch half meter square of damp 7 days later showing above the stairs
Thing is I want to keep the door on the under-stairs as it makes up the wall on one side of the living room and looks terrible with just the open space their
– could I keep it on (open up and vent the space above the door) door width and about 300mm high, then introduce louvre type vents on the vertical parts of the stairs to get air in from that side too? Maybe do the bottom 5 stairs on left and right?
In other parts of the house I’d stayed clear of injectable dpm type things but might be needed in this one spot to help
In future I’d also keep all doors open when away from the house / work etc
