Any suggestions on fryer capacity? Is 1 litre enough?
Yes, you really want as small as possible otherwise the putoine won’t fill it.
drnosh – Member
Have you got a Plutoline type number?
I googled and could only see motorcycle chain lubes. Is that what you mean?
What do you need chip fryer for?
Yes, it’s a ~1kg tub of wax for about £26.
Fryer makes life easier as you don’t need to do it in the kitchen or on a camping stove. You can just do it on the kitchen hob but it stinks and there’s the ever-present risk of spilling it and ruining the kitchen!
You basically melt the wax to about 200C and drop your clean-ish (it has to be dry with no water, mud/dirt is fine) chain in it (another win for the fryer it comes with a basket), give it a good stir to flush the molten wax through the chain and remove any crap in there, leave it for a while, give another stir etc (I go and make a cup of tea, leaving it longer IME seems to let the wax really soak through the rollers) remove the chain (carefully, it’s 200C and cools very slowly) and hang above the fryer/tin to drip, wipe it with some workshop towel to remove most of the excess before re-fitting to the bike once cool.
Because it’s a solid wax (not an oil, and not a water/solvent based wax) it won’t wash off in all but the most horrible of conditions. In terms of chain cleaning any dirt just falls off the chain and sits in the bottom of the fryer.
